Do I need a line doubler if a Set Top Box say 720p output?
radar
Posted: Sat Feb 02, 2008 1:46 pm    Post subject: Do I need a line doubler if a Set Top Box say 720p output?
Sorry if this has been answered before... I couldn't find it.
But here is a really simple question... if I have a basic Barco 701 CRT projector that can support maximum 720p, does that mean I can simply plug in a Set Top Box which has a 720p output or do I still need to buy a line doubler to force the projector to support 720p?
Kevin
jask
Posted: Sat Feb 02, 2008 6:55 pm    Post subject:
no to the line doubler.
these things are for doubling SD signals ...t.v.,vhs,etc to improve 480i images. If you were to try to feel a progressive 480P dvd signal through the doubler to your projector it would not accept it or you would end up with a bizarre double image.
If your STB has an output your barco accepts then hook it up,otherwise you will need to transcode it.
