nec xg remote
halftrack
Posted: Mon Dec 31, 2007 3:58 am    Post subject: nec xg remote
The set up remote was working when I shut off the nec now
it's not working it won't turn the nec back on or anything.
and I've checked the batteries also.
MikeEby
Posted: Mon Dec 31, 2007 4:03 am    Post subject: Re: nec xg remote
You didn't change the projector address did you? I think that could make the remote not function. I could be wrong...but its worth asking.
greg_mitch
Posted: Mon Dec 31, 2007 4:10 am    Post subject:
Are you using the remote via the infrared or with a hardwire? I remember when I was programming my universal remote I couldnt figure out why it wasn't working with my hardwired remote still plugged in.
Turns out the hardwire will disable the IR port until it is unplugged. Kind of a bummer...
halftrack
Posted: Mon Dec 31, 2007 4:14 am    Post subject:
the small remote works fine. its the setup remote not working now. but was working just fine
untill I turned the projector off.
MikeEby
Posted: Mon Dec 31, 2007 4:25 am    Post subject:
That actually makes sense because in the case of a stack or multiple projector setup. You need a way to restrict what projector you are controlling. Thats why I asked about the projector address. I forgot about the wired remote. That will come in handy after I build my hushbox. It really doesn't help halftrack out right now though.
halftrack
Posted: Mon Dec 31, 2007 6:00 am    Post subject:
I got it working I had to reset the remote.
John
timbo
Posted: Mon Dec 31, 2007 7:41 am    Post subject:
Just out of curiosity, John, how do you reset an NEC remote?
intrepid enthusiast
halftrack
Posted: Mon Dec 31, 2007 5:13 pm    Post subject:
Take the Battery out of the remote to cut the power to it. and it will reset it self to code 00.
Thats what the manual says to do.
