How much of a bend on a curved screen?
Analog_Alpha
Posted: Wed Dec 12, 2007 7:20 pm    Post subject: How much of a bend on a curved screen?
Sorry to start another topic, but does anyone know how much of a bend am I allowed to do for a curved 120" wide screen?
Thank you
Chris.
Posted: Wed Dec 12, 2007 7:30 pm    Post subject:
Depends on the size of your room, how far you sit from the screen, and how wide an "optimum" viewing area you want.
Some people curve it so the screen focuses on one central "sweet spot." That results in too much curvature for most projectors to handle properly, and the brightness drops off rapidly as you get away from the focal point. You can curve it less to spread the light out over a wider viewing area.
Try -Pjackso's spreadsheet for a calculation that takes width of viewing area into account, and shows you exactly how much to bend the screen.
Analog_Alpha
Posted: Thu Dec 13, 2007 2:50 am    Post subject:
Someone had just PM me this spreadsheet. Question though, this is all for torus screen. I just want to curve the screen from Left to Right. Would this still apply? Does curving of the screen for CRT change viewing that drastically?
Thank you
Chris.
Posted: Thu Dec 13, 2007 2:53 am    Post subject:
Just curious Analog, what material are you using?
mack1
Posted: Thu Dec 13, 2007 3:28 am    Post subject:
Chris see if you can get into this
http://archive.avsforum.com/avs-vb/showthread.php?threadid=104630&highlight=torus
it might help
Posted: Thu Dec 13, 2007 3:51 am    Post subject:
Yes, you could still use the spreadsheet to figure curve in one dimension. You might get a "vertical line" hotspot that way but it can greatly reduce brightness dropoff at the sides.
Will it help? Depends on your screen material. You should be using a high-gain material for a curve to do any good. I'd say 1.5 at a minimum, 2 or more preferred.
deronmoped
Posted: Mon Jan 28, 2008 4:42 pm    Post subject:
I went with a 18' radius. I was able to make my NEC 10PG work correctly on it. Recently I switched to a HP.
Deron.
