Another PC guru question
Posted: Sat Dec 01, 2007 3:19 am    Post subject: Another PC guru question
I bought a Global Cach'e ir learner. In the limited instruction sheet it says "The CG-IRL learner utility automatically copies the output string to the Windows clipboard, where it can easily be pasted (CTRL-V) into a spreadsheet and saved for later reference." Try as I will, I cannot seem to locate this "Windows clipboard".
oliverg
Posted: Sat Dec 01, 2007 3:33 am    Post subject:
Control C will copy "selected" content directly into the clipboard.
Control V will paste that cotnent into a selected target/destination field
The clipboard is a buffer used to save/copy temporary data. There are some utilities which enable you to populate the clipboard with more than one entry but usually people just use the one.
Good luck
Joust
TV/Projector: Marquee 8501LC
Posted: Sat Dec 01, 2007 3:39 am    Post subject:
the clipboard is a virtual thing.
you cannot "find it"
there are tools and utilities to let you see its contents and even make several so that you can copy and save 10 or even more things.
the default is one buffer of saved data. first in first out.
AFryia
Posted: Sat Dec 01, 2007 4:30 am    Post subject:
Actually you can.
The file is clipbrd.exe and clipsvr.exe under XP and found under system32.
clipbrd.exe is an app you can launch that contains the contents of clipboard.
Posted: Sat Dec 01, 2007 4:41 am    Post subject:
The upshot of this is that the info you need is already there - just do like it says and use ctrl-v to stick the info it automatically copied to the clipboard where you want it.
Posted: Sat Dec 01, 2007 7:02 am    Post subject:
Open your spreadsheet and do a 'paste' command after you have done the "copy to clipboard". THe string should apear in the field you selected.
Dave Lister
Posted: Sat Dec 01, 2007 7:05 am    Post subject:
If you want to keep the info for later use you could possibly create a notepad or word document and paste the clipboard contents into that.
The program says it is for use in a spreadsheet document so maybe using MS Excel or Open Office would be better for saving it as an easy to access file that won't disappear when you shut down Windows.
If you ever need the info again you can just open that document and copy and paste it using clipboard.
Stuff for sale;
Posted: Sat Dec 01, 2007 11:13 am    Post subject:
Thanks guys. Now it's all clear to me. What I was trying to do is "cheap out" from buying a Crestron IR Learner. They are $$$ and I only need to do a few remotes. Crestron re-badges one of the Pronto's for a wireless remote. As such can convert .ccf ir codes to Crestron ir codes. I found this Global Cach'e ir learner that can collect ir and save to .ccf format. Now that I understand how "clipboard" works, I have found that I can "paste" directly to the Crestron ir utility (Deal) and make it work. This has saved me hundreds$$ Smile
Joust
Posted: Sat Dec 01, 2007 12:01 pm    Post subject:
Actually you can.
Well I'll be dipped in sh*t. thats pretty cool.
I did not know that. thanks.
Fujifrontier
Posted: Sun Dec 02, 2007 3:43 am    Post subject:
how precious Very Happy
Heywood Jablome
Posted: Sun Dec 02, 2007 12:37 pm    Post subject:
Joust wrote:
Actually you can.
Somebody remembers the Clipboard Viewer from Windows 3.1 Wink
Posted: Sun Dec 02, 2007 4:33 pm    Post subject:
Heywood Jablome wrote:
Joust wrote:
Actually you can.
I can't even remember what I had for lunch so that little tidbit of information came in handy. The IR capture device works slick. All I have to do is capture in .ccf and paste directly into Crestrons DEAL and it's done. It's really neat being able to run both programs side by side on this widescreen monitor. I was not sure I was going to like this 24" LG flat screen monitor. Now I don't think I could live without it. Very Happy
