josh31p
| Posted: Thu Nov 01, 2007 4:10 pm Post subject: 1080p or 720p |
Hi guys
I have a barco 701, and want to know which if the folling wouyd be better:
1. Using a 1080p signal and converting it to 1080i OR
2. Using a 720p signal and converting itg to 1080i OR
3. Using a 720p signal and watching it in 720p.
The signal is being fed through a PC and the novies are only avallable in 720p and 1080p.
JustGreg
| Posted: Thu Nov 01, 2007 5:11 pm Post subject: |
Hi Josh,
Take a lookie here for a down and dirty of your pj's capabilities:
http://www.curtpalme.com/Projector_Rankings.shtm
Looks like a 7" machine with 45Mhz bandwidth will keep you at 720p/1080i. 720p is perfectly respectable tho unless you try to go with a massive screen. If you go too large it'll be dim and soft with 7" tubes even in a totally light controlled room.
But I'm a Marquee owner...what do I know.
Greg
_________________ Greg
jask
| Posted: Fri Nov 02, 2007 7:33 am Post subject: |
720p looks great
| Posted: Fri Nov 02, 2007 12:29 pm Post subject: |
Sounds like you are downloading movies and dunno whether to the the 1080p or 720p encoded one.
Always start with the best source, even if you downscale it - so a 1080p source.
I would always run 1080i minimum on the projector these days.
