AFryia
Joined: 09 Mar 2006 Posts: 965 Location: S.E. Michigan VPH-G70Q
| Posted: Sat Oct 06, 2007 10:17 pm Post subject: How Do You Clean a PJ |
How do you clean a PJ? I pulled all the tubes out for a tube swap and the bottom is dirty and dusty.
My understanding is compressed air or vacuuming is not a good thing because it can develope a static charge.
If so what other alternatives are there?
| Posted: Sat Oct 06, 2007 10:57 pm Post subject: |
Hello
Static charge? I have not heard that one before. I use canned air as it has more reach than a vacuum for tight places.
Heywood Jablome
| Posted: Sun Oct 07, 2007 1:19 pm Post subject: |
Dry air moving at high velocities thru most plastic hoses will develop a static charge. I've got a damn nice 3M Data Vac at the office that has a conductive plastic hose, ground contact between hose and housing, and even a few copper bristles in the brush heads.
I just googled it: http://www.precision.com/cleaning/data_vacuum.htm (Wow... $190 for this is a damn good price.)
I would recommend compressed air over a conventional vacuum... The danger of compressed air is the force it's capable of exerting on really small stuff (SM and ASIC semiconductors...) I limit my compressed air cleaning to 30 PSI WITH A GOOD DRYER if on an air compressor, or just use canned stuff.
_________________ "Those countries which lag behind in industry, in the application of mechanics and technical chemistry, in the careful selection and utilization of natural products, where the respect for such activities does not permeate all classes of society, will unfailingly decline in prosperity. They will sink faster when neighbor states, with an energetic exchange between science and industry, go forward with renewed vitality."
JustGreg
| Posted: Sun Oct 07, 2007 6:19 pm Post subject: |
Strap it to the roof of your car and take it for a 65MPH ride?
I use canned air also. (That's a-yah in New Englandese) Good thing it doesn't need to be done often...that crap is expensive!
The last time I cleaned the fans in mine I found that canned air wouldn't remove the lint that compacted onto the leading edge of the fan blades so I used a nylon bristled parts brush.
Greg
_________________ Greg
