Need advice ON DVD drive to PJ solution
razz1
Posted: Sat Sep 29, 2007 5:00 pm    Post subject: Need advice ON DVD drive to PJ solution
I would like to know what set up you think is the best way to go and why?
Denon dvd-800 comonent 480i out to dwin transcanner (960p) RGB out to G70.
OR
Oppo 1080i or 720p hdmi out to HDFURY RGB out to G70.
I can't decide what I want. I am currently using the Dwin Transcanner setup and it looks great!
Stonefool
Posted: Sat Sep 29, 2007 11:00 pm    Post subject: Re: Need advise ON DVD drive to PJ solution
OR
Out of those two choices, the last one. Usually the closer you get the Digital to Aanalog converter to the viewing device, the better, so unless you only have a couple of inches of analog cable from the Dwin to your pj, you're most likely better of with the Fury.
Trying to get everything to work.
Posted: Mon Oct 01, 2007 7:05 pm    Post subject:
niether one you listed. The best choice is HDMI ran directly to a Moome HDMI input card plugged directly into the G70 WITH Gamma circuit installed. Thumbs Up
