Barco 909 vs Cine9
josh31p
Posted: Fri Sep 14, 2007 10:23 pm    Post subject: Barco 909 vs Cine9
Hi Guys,
Barco 909 vs Cine9, Whats the difference and which one is better?
jantje112
Posted: Sat Sep 15, 2007 12:15 am    Post subject:
cine9 is limited in scanrange and is a little less noisy. For HT use there is no difference.
The cine9 is a colorfiltered CRT the 909 isn't
r.bauer
Posted: Sat Sep 15, 2007 6:09 am    Post subject:
Yes, jantje 112 is right, the Cine9 is 'limited' to 130kHz H-scanrange Mr. Green
RGB-bandwidth is however exactly the same, 180MHz.
If one is better? That depends on the purpose. If the 909 is colorfiltered they give both for HT use exactly the same picture. The 909 will make a lot more noise, where the Cine9 can hardly be noticed when in operation.
Come to think of it, the 909 has more electronics in it that have nothing to do with picture quality for HT-use, such as extreme geometry, so the Cine9 may be the first choice because of less excess baggage.
Besides, the Cine 9 is available in the nice grey/blue color combination. Thumbs Up
Spotmatic
Posted: Sat Sep 15, 2007 6:40 am    Post subject:
Unfortunately, the Cine 9 is far less common than the 909 (the commercial version of the Cine 9). There were not that many Cine 9's installed in home theaters. If you want one, maybe it's also an option to mod a 909 so that it essentially becomes a Cine 9 on steroids. I've heard that it should be possible to use a Cine 9 firmware in the 909 to make the fans in the 909 temperature controlled. As I understand, the temperature sensors are there in the 909, but they aren't used. The fans always work full-power.
geisemann
Posted: Thu Sep 27, 2007 7:10 pm    Post subject: Fan Noise
The 909 has lots of noise in both the power supply, Picture noise and Fan noise.
I actually prefer a 7 board modifyed 1209/2 or a 1209. Picture is just as sharp or sharper.
You have to do the mods and install high rez tubes.
The only item is the 909 has better convergance control.
The issue with the S model is the neck card BW so you cant get a as sharp picture after the mods.
We have a custom HDMI internal card for the 909 that provides sync right into the motherboard.
A Fan mod is necessary on the 909 its way to loud.
The thermo controllers work on the 909 but they are set at a much higher level for simulation box install.
Greg
www.eisemann-theater.com
jantje112
Posted: Thu Sep 27, 2007 8:08 pm    Post subject: Re: Fan Noise
Greg
So you will trade your 909 machines against the barco 1209 or is this just a sales talk?
