marquee remote
derfla
Posted: Fri Sep 07, 2007 3:53 am    Post subject: marquee remote
How do I make my wired remote work with the ir? I did a search but turned up nothing.
derfla
Posted: Fri Sep 07, 2007 4:02 am    Post subject:
never mind i figured the search out.
innof
Posted: Sat Sep 08, 2007 10:09 pm    Post subject: Details
Hello. Please do elaborate as to how you succeeded here since I'm not able to get my IR remote to work with my Marquee. Thanx.
GEBrown
Posted: Sat Sep 08, 2007 11:09 pm    Post subject: Re: Details
Are you talking about your "Marquee" IR remote or some other brand?
Posted: Sat Sep 08, 2007 11:30 pm    Post subject: Re: marquee remote
Hello
Before disconnecting from the projector, fire up the Marquee and push "STAR" and note the IR status of A, B , or OFF. If off, go into the Service Menu and activate IR.
If it is the better type with movable jumpers, pop off the battery door, unplug the cable if still connected, and set the jumpers to "DOWN DOWN DOWN UP"; this is Protocol A; install four AAs and you should be all set unless the IR is disabled in the projector.
For Protocol B, set all jumpers to DOWN
innof
Posted: Sun Sep 09, 2007 4:35 am    Post subject: Type
It is indeed the original marquee IR remote.
PJMoore
Posted: Sun Sep 09, 2007 1:39 pm    Post subject:
Like Tim says - you must FIRST use the tethered remote to ensure the IR is activated to protocol A or B, then untether and reset the remote jumpers per this document, and add batteries.
Joust
TV/Projector: Marquee 8501LC
Posted: Sun Sep 09, 2007 2:39 pm    Post subject:
Ok nest step.
How can you program one in a universal remote.
the power button must be held down. how can a universal do that?
Heywood Jablome
Posted: Sun Sep 09, 2007 2:45 pm    Post subject:
Joust wrote:
Ok nest step.
Was'nt there a thread or two for discreet power with marquees and URC remotes?
aspec2
Joust wrote:
Ok nest step.
My Pronto works fine with Guy Kuo's CCF file.
Walt
Heywood Jablome
Posted: Sun Sep 09, 2007 2:46 pm    Post subject:
Yep... there it is: http://www.avsforum.com/avs-vb/showthread.php?t=893114
