Joust
TV/Projector: Marquee 8501LC
| Posted: Fri Aug 17, 2007 5:23 pm Post subject: Lumens confusion |
I'm looking at brocures for Digital Projectors. (NO, I'm not considering one) and they quote 2000 ANSI lumens.
my Marquee quotes 250 ANSI lumens and 1200 peak Lumens.
so are the digitals in reality Peak or ANSI lumens. I want to be able to compare apples to apples.
| Posted: Fri Aug 17, 2007 5:35 pm Post subject: |
Digitals are pretty much the same on ANSI and Peak. They have the same max lumen output (per area) whether you're displaying a window, a checkerboard, or a full white screen.
CRTs are current-limited, and it takes current to display bright areas. As you display a larger and larger bright area, you hit the current limit, and the projector drops its max brightness level to keep within the limit. So their peak lumens (on a small area) are much higher than the lumen output on a full-white screen.
So yes, assuming everybody measured the same, that digital really is 8 times brighter than your Marquee! At least, it is on an ANSI lumen test. On actual video content (unless you're watching Ice Age or something else with tons of bright-white scenes) there won't be as much difference. The Marquees have a peak lumen rating of 900-1300 depending on model, so for actual video content, the digital might only look about twice as bright.
Joust
| Posted: Fri Aug 17, 2007 5:40 pm Post subject: |
well, how much does that suck?
Rdean
| Posted: Fri Aug 17, 2007 5:44 pm Post subject: |
Stack. Pretty soon everyone's gonna be doin' it right? I may have to give in someday...
Joust
| Posted: Fri Aug 17, 2007 5:51 pm Post subject: |
| Rdean wrote: | | Stack. Pretty soon everyone's gonna be doin' it right? I may have to give in someday... |
thats crazy talk.
someone should contract a Chinese manufacturer to make newer higher output tubes cheaply. there is money to be made there.
as bad as it sounds, I'll probably wait, live with what I have and get a digital once they reach a contrast ratio of 20,000:1 or better.
| Posted: Fri Aug 17, 2007 6:45 pm Post subject: |
Don't forget that 2000 ANSI lumens figure is the day you take the projector out of the box. It starts going down hill from there. Depending on the projector and bulb in question, it could be down to as little as half that 2000 ANSI lumens in 1000 hours. Also consider, that in a dark room, on a reasonable size screen, most of our CRTs are plenty bright, even in mixed scenes. Consider also, that unless you like watching a lot of movies about going from dark caves into snowy fields, it just doesn't matter that much. I'm not willing to sacrifice everything I like about CRT and tolerate everything I don't like about digital just to get more brightness and a little box. It still looks like it's going to be at LEAST 2-3 years (if not more) until the cost/benefit mix will start looking acceptable (justifiable money-wise) to me on the digital side.
Joust
| Posted: Fri Aug 17, 2007 6:51 pm Post subject: |
Good points, I agree, ecrabb
It still sure would be nice to get a new source for better tubes at a cheaper price
| Posted: Fri Aug 17, 2007 6:53 pm Post subject: |
Good point SC. In fact lots of bulbs end up with 40-50% drop in lumens in much less than 1000 hours -- I've heard as little as 300-400.
Also, you very seldom get anywhere near the rated lumens by the time you calibrate the display.
I figure I'll stick with CRTs until they perfect LED light sources or something similar. I don't want a hot bulb that degrades rapidly, costs a ton to replace, bakes the optical path, etc. I also don't want DLP because I see rainbows. On the other hand I don't especially want a 3-chip solution with non-correctable convergence errors either. I hope within 5 years they have a better technology. If not, I may be scouring ebay for another CRT.
Joust, I don't think your Chinese manufacturer could increase the lumen output that much, even if he adds antifreeze. We're already pushing the phosphors about to the max. About the only ways to increase lumens are to push the phosphor harder (which burns it out much faster) or increase the phosphor area (can you say 9"? ). Unless you're going to start manufacturing 10" or 12" tubes, I don't think there are many options to increase the light output. You're better off to stack.
Joust
| Posted: Fri Aug 17, 2007 7:02 pm Post subject: |
ok ok you talked me into it.
now all i need is a newer green tube that i can put in my bench machine.
papalek
| Posted: Fri Aug 17, 2007 9:48 pm Post subject: |
Maybe if you could actually make a glycol circulation system.
What if you used the fill holes to be outlets and inlets for glycol to be circulated. You could run lines to a refrigeration system to keep the glycol real cold and consistently cold. If the face of the tube was kept cold, you could turn up the contrast and not burn the phosphors.
Am I on the right track or am I barking up the wrong tree.
_________________ My current list of PJ's AmPro 1 1/2-4600,4200, 1/2-3600,2600.
I do love my AmPro's
Joust
| Posted: Fri Aug 17, 2007 9:56 pm Post subject: |
Cool overclocking CRT projectors
VideoGrabber
| Posted: Fri Aug 17, 2007 10:09 pm Post subject: |
Joust asked:
> well, how much does that suck? <
Not much at all. Really.
_________________ - Tim
Joust
| Posted: Fri Aug 17, 2007 10:23 pm Post subject: |
| papalek wrote: | Maybe if you could actually make a glycol circulation system.
Am I on the right track or am I barking up the wrong tree.  |
I guess the real question here is, "Is it the tube face getting hot that allows the phosphor to burn."
I'm not so sure it really is. The LC machines have a lot more glycol in them and they burn too. Also, if this were true, then the ones with patterns burned in would be more diffused because the liquid cooling would spread that heat more evenly across the tube face. However, some of the examples shown on this forum are quite well defined.
my 2 ¢
| Posted: Fri Aug 17, 2007 10:37 pm Post subject: |
I think "burn" is really a misnomer. Maybe somebody could chime in with a better description of the actual chemical process, but I think it's more along the lines of oxidation (not that it is - I know, little oxygen in the tubes, but more like that), than it is anything getting hot or burning. I think the coolant serves two purposes: 1) Keeps the glass from breaking from the thermal stress, and 2) Keeps the tube face at an overall cooler temp, which does extend the life (or decelerates wear process (whatever the process technically is).
Joust
| Posted: Fri Aug 17, 2007 11:25 pm Post subject: |
i think when it is turning brown, it is indeed burning. Perhaps when it looks black it is either burned really badly or has vaporised inside the tube so its simply not there on the tube face anymore. purely speculation on my part.
WTS
| Posted: Sat Aug 18, 2007 3:12 pm Post subject: |
Speaking of phosphor usage, wouldn't using 1080i instead of 1080p make your tubes phosphor last longer? I've often thought about this but could never arrive at an answer.
_________________ Thanks
Walter
VideoGrabber
| Posted: Sat Aug 18, 2007 6:21 pm Post subject: |
Walter,
if you had everything set up for 1080p, then dropped it to 1080i while changing nothing else, would the perceived brightness drop? If so, then when you adjusted contrast to get back the same level of "punch", you'd be back at the same wear level again.
In general, phosphor wear is a function of beam current and time, the same factors that govern light output. While you can decrease wear by measures like reducing screen size, increasing screen gain, utilizing maximum phosphor area, and (to a lesser extent) controlling the environment (dark walls, etc.); to produce a specific desired amount of light output will mean driving the tubes just as hard, whether it's with higher currents for shorter intervals, or lower currents for longer intervals. TANSTAAFL.
WTS
| Posted: Sun Aug 19, 2007 3:30 pm Post subject: |
Okay, looking at it that way does make sense, thanks.
Walter
| Posted: Sun Aug 19, 2007 10:21 pm Post subject: |
| Joust wrote: | | i think when it is turning brown, it is indeed burning. Perhaps when it looks black it is either burned really badly or has vaporised inside the tube so its simply not there on the tube face anymore. purely speculation on my part. |
I remembered differently, so I did some reading and thought I'd start a whole new thread to discuss the process in more detail. Feel free to chime in!
What really causes CRT wear/burn/aging? What is it, really?
