Tinman
Joined: 09 Mar 2006 Posts: 1326 Location: Carson City Nevada
| Posted: Fri Jun 15, 2007 11:55 pm Post subject: Sony SD-208 Tubes |
Hey Guys.....
I just ran this by Curt, but to my surprise he doesn't know this either.
A large quantity of Sony SD-208 tubes that also cross to 07MSU's.
Anyone know what they fit? They come out of short throw video cubes. Looks like an SD-187 without colored glycol. These have the multi-pole astig rings on the back to boot.
I can pull a set to play with. Hate to see them get scrapped if we can use them in 10XX or ECP's.
Marc
_________________ This space for rent.
banzairun
| Posted: Sat Jun 16, 2007 1:23 am Post subject: |
I have a few of these new.. reds and greens I think. I tried finding out what they were used in and always came up dry.. the only useful thing I recall hearing about them is that they use a heavier phosophor so they'll last longer, but are otherwise identical to SD-187.
the ones I have are attached to LC chambers I think, so a use in rear-pro videowall cubes makes sense. I guess if anybody is interested in them let me know..
Jeff
Sonynut
| Posted: Sat Jun 16, 2007 4:19 am Post subject: |
I had 3 from a Sony RVP-401Q. Basically a 1270 electronics-wise, but a 41" rear-pro cube meant to be in/on a wall. The one I had came from the Nasdaq wall specifically.They should work nicely on a 10xx I would think, just removing the LC assemblies and converting the to AC is the fun part. They seemed slightly brighter than the 07MS and SD187's I have seen.
Dave Lister
Joined: 16 Jan 2007 Posts: 436 Location: Adelaide, South Australia
| Posted: Sat Jun 16, 2007 8:33 am Post subject: |
What condition are they in?
I have a VPH1000QM that uses SD-187 tubes that have 80,000 hours on them, swapping the glycol shouldn't be much of a problem.
Tinman
| Posted: Sat Jun 16, 2007 3:20 pm Post subject: |
Tubes are in good shape, the one I looked at had the mildest 4:3 wear on the blue.
When I go back, I'll pull a set and see what can be done with them.
Marc
alangeering
Joined: 09 Apr 2008 Posts: 6 Location: Bournemouth, UK
| Posted: Wed Apr 09, 2008 3:21 pm Post subject: |
Did you get anywhere with these.
My brother has just bought some of these with friends but has had no luck getting them working so far.
Any information appreciated. I was directed here by members of AVForums.
Alan
