S-Video Cable
Bill913
Posted: Fri Jun 08, 2007 4:09 pm    Post subject: S-Video Cable
I am new to the forum and have a basic question. I need to run a S-video cable about 28 ft. I have been told that this is to long for svideo and was wanting to know if this is true and if so is there a solution. Thanks for any help.
Person99
Posted: Fri Jun 08, 2007 5:06 pm    Post subject:
You can run it that far if it is made from high quality mini coax. If you want to be sure, you can use s-video breakout adapters so that full size coax carry the signal. Both are available here:
http://www.bluejeanscable.com/store/svideo/index.htm
Also, why do you want to run s-video that far? Please, for the love of god tell me it is not to hook to your CRT PJ.
zaphod
Posted: Fri Jun 08, 2007 5:12 pm    Post subject:
its obviously to hook up the LD player. makes it easier to hug the player if you have it on the sofa beside you.
Person99
Posted: Fri Jun 08, 2007 5:27 pm    Post subject:
Man, I have been working alot (weekends, some nights 'til after midnight, etc) and am beat. Thanks for the best laugh I've had this week. Thumbs Up
zaphod
Posted: Fri Jun 08, 2007 5:29 pm    Post subject:
Good Lord, we're playing well together. Don't tell Dad. Mr. Green
have a good weekend.
Posted: Fri Jun 08, 2007 6:50 pm    Post subject:
You'd probably get home sooner if you stopped posting so much on the forum.... Wink
Person99
Posted: Fri Jun 08, 2007 6:51 pm    Post subject:
Yeah, I would. But, posting is my only "break". I even eat lunch in front of the computer working. But yes, I'm starting to post less and shorter. Look, Pete just bagged on me for my super abbreviated review of the Fury.
JustGreg
Posted: Fri Jun 08, 2007 7:27 pm    Post subject:
As a rule, the shorter the cables, be it audio or video, the less likely you'll introduce unwanted artifacts or abberations. A good solid method that doesn't cost a ton of money and provides you with the absolute best results over long runs, compared to an ubber long S-vid cable, are baluns. You have to have a sender and a receiver and they are cabled together via inexpensive CAT5 cable.
I'm using these to feed the 17" LCD monitor in the bathroom outside my HT. For what I'm using it for, the quality is quite good.
http://www.fullcompass.com/product/317095.html
Another alternative is a video/audio sender/receiver pair from Radio Shack or directly from X10.com. The problem with these is that basements are electronically noisy places and the received results aren't always the greatest...at least my basement is noisy that way.
Greg
Greg
zaphod
Posted: Fri Jun 08, 2007 7:53 pm    Post subject:
Greg
i've thought about that too. that way someone's bladder doesn't make the rest of us wait. i figure that the sound in the HT is loud enough to not need speakers around the corner, but seeing the picture around the corner is a no go. driving the 40' will probably require baluns, thanks for the link.
one of my worries is moisture. that bathroom has a shower making it a moist place sometimes.
Person99
Posted: Fri Jun 08, 2007 7:58 pm    Post subject:
zaphod wrote:
Greg
You are probably no going for impecable image quality in that room. Smile I've thought of doing the same and I was just going to run stereo analog audio to it. So, they would hear what they needed to.
CRT_Ben
Posted: Fri Jun 08, 2007 8:13 pm    Post subject:
Awwww, some strategically placed mirrors would do the trick Wink
JustGreg
Posted: Fri Jun 08, 2007 8:40 pm    Post subject:
zaphod wrote:
Greg
The display I'm using is actually for RV/Van/etc use so it's made pretty rugged. The only thing I had to do was take it all apart and reverse the display in relation to the main body so that it no longer has to flip down. It's just one "solid" piece now. The bathroom I use it in has a shower too but it's never used.
And seeing as I'm getting stereo sound over the baluns anyway, I mounted some old Lineum bookshelfs I had from a Rat Shack stereo system and am feeding them with a subwoofer amp from a computer I had eons ago. The "ugly" part of the arrangement is all inside a small linen closet on the top shelf. The outter wall to the linen closet has the monitor mounted on it with a small, 1" hole to feed it. The wires for the speakers are up in the suspended ceiling.
The hardest part of the whole thing was figuring out where to mount the monitor so both sexes could see it whilst, well, using the facilities. Laughing
But you're right....nothing worse than stopping the movie a lot out of respect for those with acorn sized bladders (my wife!).
Greg
Greg
JustGreg
Posted: Fri Jun 08, 2007 8:48 pm    Post subject:
Person99 wrote:
zaphod wrote:
Greg
The image actually looks surprisingly good...well, once I unscrewed every other 60w bulb in the light bar over the top of the vanity. Shocked I was given the flip down 17-ish" display NIB which retails for around $500, so putting a coupla bucks into making it work was an easy decision. It gets the nice oooooh response too. Embarassed
Greg
Greg
Bill913
Posted: Mon Jun 11, 2007 2:50 pm    Post subject:
Thanks much to everyone that replied to my question, I think
Bulejeans has a good solution. And, no I am not feeding my projector this way. I use RGB for the projector which is a NEC 6PG Extra connected to a NEC LD200. Does anyone have a suggestion for scaler that would give me 1080I that doesn't cost a fortune? Again thanks for the help.
Person99
Posted: Mon Jun 11, 2007 3:39 pm    Post subject:
What do you need to scale. Pretty much every source will do 1080i now. So, you have your HD cable doing 1080i, your HD DVD and/or BD doing 1080i, and you can use an HD DVD player or good upscaling DVD player to do 1080i. If you are scaling something else, you might need one. Gefen has some solutions which are under $400 though not as high quality as a used Lumagen that you could get for around $800.
