kal Forum Administrator
JohnHWman
Joined: 15 May 2007 Posts: 215 Location: France - Grenoble
TV/Projector: Sony VPH-G90U (one unit for me, four others units repaired and sold)
| Posted: Thu May 17, 2007 9:17 pm Post subject: |
There was a thread on AVS that talked about it. I should try to find it...
John
_________________ Home theater enthusiast for over 20 years !
My dedicated HT room !
JohnHWman
rickwick
| Posted: Fri May 18, 2007 3:58 am Post subject: |
OT somewhat Bomrat describes a Sony mod to a repaired df board in buy and sell section currently and glassact describes a critical chip replacement on that other forum for the G90.
JohnHWman
| Posted: Fri May 18, 2007 7:00 pm Post subject: |
Yes Kal,
Money is not the first point about this, the challenge is more interesting 8)
One first way to go from my POV is to use a 500MHz oscilloscope, on BA board R or G or B paths. Feed 1080p signal with 1:1 B/W vertical lines test pattern on HD-DVD (HDMI outputed from toshiba XA2 and inputed to IFB-DVI card within G90 B slot) and probe all the video analog stage outputs Vpp to establish the weakest stage(s) in this signal path from IFB-DVI board until 'C' block on tubes necks.
Then we'll know were to put our efforts to inprove the stock 135MHz VBW to the highest value versus mod. cost (and technical limitations too).
Just one starting idea about this
John
g90man
| Posted: Sat May 19, 2007 8:27 pm Post subject: |
Why John, it seems you're halfway done already! I'm really hoping this is something you are pursuing. Cross our fingers.
JohnHWman
| Posted: Sun May 20, 2007 9:38 am Post subject: |
I'll do, but probably later-on since I'm currently buzzy with my third G90 arrival (need to be retube) and IFB-DVI shipments
John
Brian Hampton
| Posted: Sun May 20, 2007 2:05 pm Post subject: |
Third G90.
Jeez. That's amazing.
-Brian
Joseph
| Posted: Sat Dec 22, 2007 3:50 pm Post subject: |
Thought I would bring this topic back from the dead; I'd love to see something done in the area of G90 modding, since
(like most everyone in this hobby), I'm always looking for ways to improve things. And as Kal wrote, the G90 doesn't lend itself to modding. I wonder if John has put any more thought into this?
| Posted: Sat Dec 22, 2007 4:15 pm Post subject: |
| Joseph wrote: | | Thought I would bring this topic back from the dead; I'd love to see something done in the area of G90 modding, since )like most everyone in this hobby), I'm always looking for ways to improve things. And as Kal wrote, the G90 doesn't lend itself to modding. I wonder if John has put any more thought into this? |
Agreed, as I would love to feed my stack 1080P/72. I would also like to see the minor streaking addressed as well.
Cliff
JohnHWman
| Posted: Sat Dec 22, 2007 5:52 pm Post subject: |
Yes, I understand guys ...
I would love doing these investigations but since I catched a new job in october, my spare time is quite low nowadays...
I still did not find time to change my own G90 unit Green C element (and redo 6500°K calibration) nor finishing my HT new wiring
Maybe the day I'll catch my fourth G90, I will do it as it's always easier to do this kind of job on a spare machine rather than the one you use everyday As soon as someone is selling a G90 damn cheap, I'll buy it
Merry christmas to all
John
Joseph
| Posted: Sat Dec 22, 2007 8:02 pm Post subject: |
John, you've contributed so much to the community, I can't imagine anyone would complain about your schedule! FYI, I also revived the AVS Forum thread referenced in this thread, so perhaps there will be some activity there as well. Happy Holidays John!
| Posted: Sun Dec 23, 2007 2:19 am Post subject: |
| JohnHWman wrote: |
John |
It would be interesting to see what "135mhz bandwidth" actually means. They mention no conditions (-3dB? -3dB from what? At what Cathode drive level, etc, etc). We know the G70 frequency response is nowhere near flat - someone measured it (maybe you? I forget).
I fear that the bandwidth specs bear no resemblance to reality, for all CRT projectors.
JohnHWman
| Posted: Sun Dec 23, 2007 10:09 am Post subject: |
Hello Mark,
VBW is measured on video signals (0dB - 0.7V peak white on 75 ohms load) at the frequency where signal is lowered to -3dB.
Yes, this was me who did measurements of the G70 VBW between A and B inputs (three years ago). I did this only on the video side of the B board and not on the C blocks.
For the G90, this value is 135MHz and I assume that Sony made this measurment including the C block circuit (the VPJ15 video C blocks amp/drivers (G1/K) are rated at 150MHz). Cathode drive level should not matter as -3dB is relavive to the in-band cathode level (from within frequency response).
First (and easiest step) is to precisely measure the VBW of the BA board by inputing various RGB pixelclock frequencies (using Powerstrip for example) in either A or B(C) inputs of the projector and probe the C block delivered video RGB signals to catch the BW limit at -3dB. If this VBW is around 135MHz, then, we are sure that something can be done inside BA board circuits to increase this limit (by finding what is or are the blocs where this limit comes from 8) ).
If not, then the limitation comes from the C block circuits and we should work on the C block to extand this limitation (change of G1/K amp/drivers for example). But this part of the electronic is more complex to tweak since this would means special probing equipments due to the HV presence ...
Just my first thoughts
John
Ile
| Posted: Sun Dec 23, 2007 2:01 pm Post subject: |
| overclkr wrote: | I would also like to see the minor streaking addressed as well.
Cliff | Anybody have picture of this? If I remember correct it was only few pixel long...
VPA18 is straight swap over VPA15, but need probably different peaking components.
JohnHWman
| Posted: Sun Dec 23, 2007 3:43 pm Post subject: |
| Ile wrote: | VPA18 is straight swap over VPA15, but need probably different peaking components.  |
G90 is using VPJ15 video packs from Sanyo and not VPA15. I don't know what are the differences and I tried to find more info on Sanyo Website without success. If someone knows where to find the relevant DS, please post here.
According to Sony G90 schematics (i.e. CDB board), the VPJ15 is powered through +100V DC PS. According to Sanyo video packs summary DS, the VPA15 is powered at 80VDC so I assume that VPJ15 devices doesn't have the same specifications as VPA15
John
Ile
| Posted: Sun Dec 23, 2007 10:18 pm Post subject: |
Yep, those have different specs.
VPA15/VPA18
max. Vcc 90V
Vout 40Vpp (80Vcc)
Gain 14
VPJ15 http://www.tenfourltd.com/pdf/SY103A_e.pdf
max. Vcc 120V
Vout 50Vpp (100Vcc)
Gain 15
JohnHWman
| Posted: Mon Dec 24, 2007 9:17 am Post subject: |
Thanks for the link Ile,
I'm quite suprized that the complete VPJ15 datasheet is so hard to find on the net ...
Anyway the VPJ15 Vout is far better than VPA18 and this should be a problem to use VPA18 for the G90. Don't know if VPJ18 did exist ...
My feeling woud be that 135MHz (-3dB) of the G90 comes from BA board and we should be able to extend it until 150MHz without too much difficulties
John
Joseph
