Gav143
Joined: 12 Apr 2007 Posts: 4 Location: Newcastle, Australia
| Posted: Thu Apr 12, 2007 10:06 pm Post subject: Help with a D50 |
Hi, I have just purchasd a Sony D50. I noticed that there is a little fungus on the red lens, How would I remove it? alos on the rear there are 5 bnc plugs 3 are the RGB plugs but what are the other 2?
Gav.
whats6x7
| Posted: Fri Apr 13, 2007 3:43 am Post subject: |
Hi Gav,
I believe this is the correct procedure to just use component . . .
Connect the DVD player’s component output into Input A.
In the SET SETTING menu select HDTV-YPbPr for Input A.
In the INPUT SETTING menu highlight Sync and select EXT (HV).
The IDTV module disables itself automatically.
Analogs right though. All those are GREAT links.
_________________ it takes a village, but not just any village—and certainly not the village of Corleone on the outskirts of Palermo, Sicily!
Gav143
| Posted: Fri Apr 13, 2007 10:15 pm Post subject: Thank you |
Thank you for your quick replies, I did not think it would be so easy to get help, so thanks again.
d50q
| Posted: Fri Dec 07, 2007 2:59 am Post subject: so you dont need a scaler? |
im confused?
| Posted: Fri Dec 07, 2007 3:30 am Post subject: |
Funny, i had forgotten about this post ( and with 3886 of them I'm not surprised )
I was looking at a D50 yesterday. It can take component on the BNC conectors. Not sure which card is installed ( IFB-12 maybe? ) but it's a handy feature some of the projectors have.
d50q
| Posted: Fri Dec 07, 2007 3:45 am Post subject: i mean transcoder |
i meant transcoder anyway its almost bedtime but i have to go look before i sack out.
| Posted: Fri Dec 07, 2007 8:54 am Post subject: |
Have a read in the manual. It tells you about this neat input card.
http://www.curtpalme.com/docs/SonyD50_User.pdf
That is if no one's swapped it for another card.
