Marquee 9500LC Ultra bow issue
ElTopo
Posted: Tue Mar 04, 2025 12:45 pm    Post subject: Marquee 9500LC Ultra bow issue
Hi all,
may anyone out there could tell me what board is responsilbe for the bow options ?
The bow settings do not work at present on my setup. Either on top or bottom.
Help much appreciated
thanks
ElTopo Thumbs Up
Barco Cine 9 the one and only
Posted: Tue Mar 04, 2025 7:53 pm    Post subject:
Guys
Likely the control board or geom/focus. Look for glycol leaks between red and green tubes onto the top mother board.
ElTopo
Posted: Wed Mar 05, 2025 2:40 pm    Post subject:
Thanks Tim.
Will check for a spare board.
Posted: Wed Mar 05, 2025 9:59 pm    Post subject:
Indeed the bow settings are generated on the CLM -along with pincushion. therefore it would be strange if only the bow is not working but the pincushion does.
Anyway be careful with changing around CLMs on a well set-up system, because it may lead you to projector reinitialization with all your settings being lost.
ElTopo
Posted: Thu Mar 20, 2025 9:32 pm    Post subject:
It seems the issue is caused by the geometry board. Bow works again after changing the board.
thanks for your support
ElTopo
