Barco 909 refresh rate
Hypno89
Posted: Thu Sep 12, 2024 11:27 am    Post subject: Barco 909 refresh rate
Hello guys,
I wanted to ask - what is maximum vertical refres rate of Barco 909?
In the specification overview from Curt palme is written 210 Hz, however in official brochure there is on page 3 written 240 Hz.
http://www.curtpalme.com/PJSpecs_Barco.shtm
https://www.projektoren-datenbank.com/pdf/barcoreality909.pdf
Hulio
Posted: Thu Sep 12, 2024 1:23 pm    Post subject:
240. Cine 9 (CineMax) have a software limitation of 210 Hz, in order to run the fans less loud.
Posted: Thu Sep 12, 2024 5:12 pm    Post subject:
Other than very specific simulator applications, why would you want to use 240Hz let alone 210Hz or anything over 60? (or maybe 120 if you game).
HaydnG90
Posted: Thu Sep 12, 2024 5:36 pm    Post subject:
72Hz was a noticeable improvement over 60Hz on the G90. Sharper, more saturated colors. I wouldn't go back. I believe there were also some advantages with the interpolation of native 24fps out of the bluray player with 72Hz vs 60Hz.
Posted: Thu Sep 12, 2024 6:30 pm    Post subject:
I don't doubt what you're saying, but why would refresh rate affect sharpness and colour saturation. They shouldn't.
In fact, sharpness should decrease as with higher refresh rate the raster is now moving faster and the slew rate (rise/fall time) needs to be shorter but it will be more rounded on the rise/fall given the faster speed, so less sharp.
Colour is completely different.
Hypno89
Posted: Thu Sep 12, 2024 7:06 pm    Post subject:
Thank you Thumbs Up
The latter option Smile However, since I still want to achieve a solid resolution, blending would be required, which makes this hobby attempt quite challenging.
Posted: Mon Apr 21, 2025 11:37 pm    Post subject:
Because you can, and because it actually works on a CRT. Makes sweet FA difference on most digitals.
Posted: Tue Apr 22, 2025 12:53 pm    Post subject:
"Because you can" isn't much of a valid reason. Wink
The higher the refresh rate on analog signals like what's used in CRT projectors the softer the image gets as the raster and other analog circuitry doesn't have time to change state as sharply. So edge transitions are softer. It's like driving down the road and wanting to turn 90 degrees left or right from one street to another. If you're doing 5 km/h you can turn a lot sharper than if you're doing 50 km/h.
Digitals don't have this issue (directly). They can either do it or they can't.
Refresh rate on digitals does matter for some uses, like gaming. Just like gaming monitors (digital) there are many higher refresh rate digital projectors that can do up to about 240Hz. Gaming monitors go up to about 480Hz.
High refresh rates in games leads to reduced motion blur, improved control, and a lower perception of input lag. Mostly noticeable in fast-paced games.
I game on my JVC NZ7 which can do up to 4K/120Hz though the types of games I play aren't face paced (usually) so I really don't care. High refresh rate wasn't one of my needs when I bought this projector.
virusc
Posted: Wed Apr 23, 2025 10:24 am    Post subject:
If you even want to try going over 72hz I hope you have a fast phosphor Green tube right which is very rare and lowers light output? Also you are aware even if you wanted to try out 200hz it is at 480p maybe. The high refresh rate is for special use not even for simulators but for probably taking pictures of the screen synced for high frame rate for slow motion or something. Practically over 120hz has no use. Even 144hz on a CRT for 3d you would be better off with a lower rate it is going to ruin picture quality for no improvement.
Posted: Sun Apr 27, 2025 11:52 pm    Post subject:
Not sure why you're explaining all this to me Kal, i'm a 54 year old man, been gaming since the begining of time Laughing
Good luck getting any digital to refresh at 480Hz and look any different to 240Hz, it's probably interpolated at that.
The thing about input lag is CRTs don't have it, all digitals do.
Posted: Mon Apr 28, 2025 12:30 am    Post subject:
I have you beat by 1 year. Wink
The problem is you haven't kept up with technology and you're talking gaming from ~10-20 years ago. I probably game exactly like you (I have zero interest in high refresh twitch games) but that doesn't mean higher refresh rate doesn't exist and make sense sometimes.
Some gaming monitors now will do 480Hz. It's not for the sort of games I like to play (or probably the ones you play), but for esports players playing "twitch" games with high end GPUs it can and does make a difference. It's not interpolated. I'm not sure why you'd think that. Using something like DLSS (on Nvidia GPU) or FSR (AMD GPUs) adds input latency so these twitch gamers wouldn't use it.
I have zero interest in these sorts of games at that refresh rate (as probably do you as mentioned) but you should do some research into what exists today even if it's not what you like to play as these things do exist and do matter to some people. Competitive gamers playing (for example) COD or LOL will lower settings and even resolution to hit higher refresh rates because that's what helps when it comes to winning esports.
None of this existed not that long ago so it doesn't matter how long you've been gaming. If you haven't kept up with what some gamers are doing it's normal that you wouldn't know as you have no interest. I certainly don't care - I'm happy with a "low" 60fps as I don't play competitive and have zero interest in it. I prefer big open world games where this doesn’t matter. Recent ones I spend hundreds of hours on include RDR2, Starfield (boring unfortunately) and Cyberpunk 2077. Looking forward to replaying the remastered version of TES Oblivion next. What are you playing?
Posted: Tue Apr 29, 2025 11:37 pm    Post subject:
For anything new, i'm VR sim racing only, Assetto Corsa Competizione mostly, but a bit of rFactor 2 and some Automobilista 2 from time to time if i don't feel like a competition race. I do play the last 3 Tomb Raider games, at 4096x2160 on my Sony SXRD, but haven't had any interest in anything else newish. The 570ES only has about 28ms input delay so it is better than majority of TVs probably are. Still not nearly as good as the zero input delay on the Barco, but for modern games programed with lag in mind that is still well under where it really needs to be for Mario Kart.
If i'm playing console games, in this order, it'll be NEO-GEO, Mega Drive, Master System, 3DO, Saturn, PS1, WiiU, Switch, PC Engine, NES, SNES, Atari 2600, and maybe Dreamcast and PS2. All on the Barco, or on a 68cm Sony CRT TV, all using RGB direct from the console except the WiiU and Switch for obvious reasons.
Out of all that, the WiiU and Switch are the only two that will ever get used on the 4K SXRD projector, but truth be told they look every bit as good on my Barco Cine 9 anyway because the blacks are still better. Both projectors are on the same 135" 16:9 screen, with the Barco dead center and the Sony sitting beside it due to it's brilliant lens shift abilities.
Posted: Wed Apr 30, 2025 9:35 pm    Post subject:
Holy crap! That's a long list of consoles!
P.S. Sorry to the OP as we've gone completely off topic...
