The Barco CINE7 fans are not running. What is the reason &am
bluemoonhu
Posted: Mon May 20, 2024 6:10 am    Post subject: The Barco CINE7 fans are not running. What is the reason &am
The Barco CINE7 fans are not running. What is the reason ?
Thank you!
Posted: Mon May 20, 2024 7:42 am    Post subject:
Does the projector come out of standby mode and run?
bluemoonhu
Posted: Mon May 20, 2024 10:00 am    Post subject:
After the projector is turned on, all fans do not work, so the machine cannot run, that is, the projector's tubes cannot be lit up.
Posted: Mon May 20, 2024 10:51 am    Post subject:
Its unlikely that the fans are the cause of the projector not starting. I would suggest that the projector is not starting so the fans don't either.
If you look through the posts on this site as well as the projector documentation you will have enough knowledge to determine where the issue is.
It could be a "Scan Fail" issue or even just a bad Power Supply.
I am not sure about the Cine 7. Is there an LED on the back that lights up when power is supplied to the projector? Its usually red when the projector is off and then goes to green when you start the projector.
If its red when power is supplied to the projector before you try to start it then power is supplied to the PSU. If you press the power button on the remote and that LED stays red then its not coming out of standby.
There are other LEDs in the set that will help you with where the issue is. Check the manual for Scan Fail.
bluemoonhu
Posted: Mon May 20, 2024 11:35 am    Post subject:
When the remote is pressed to start, you can see that a row of LEDs in front of the machine will intermittently light up green, while the red LED of the standby power supply will always light up. And all fans always stop working
Posted: Mon May 20, 2024 10:34 pm    Post subject:
The green LEDs are always supposed to be green and be on solid when the projector is on. If they are turning on and off, there is a fault condition in the projector, causing the projector to turn on and then off again. It will repeat that 3 times before shutting down completely if the fault remains.
bluemoonhu
Posted: Tue May 21, 2024 1:21 am    Post subject:
Yes, I don't know which board the problem is on. I've never encountered this situation before。
Posted: Tue May 21, 2024 3:05 am    Post subject:
It won't be easy to narrow down. That's where you have to sit with the service manual and check to see what circuits are working.
