SDR vs HDR for a noob.
Andre Ghost
Posted: Sat Oct 22, 2022 4:00 pm    Post subject: SDR vs HDR for a noob.
Hello experts.
I'm in a pickle with regards to calibrating my Sony X90K.
I kinda read the guide but am still very much lost.
My laptop isn't that powerful and unable to display HDR. All i have is my laptop with CP3 installed, an i1 Display Pro+ and my TV. As for my media device, I'm using an Nvidia Shield TV Pro. I've set my Shield to display under the following settings.
3840x2160
60Hz
YUV 422 12-bit
Rec. 2020
Dolby Vision and HDR10 Ready
Considering the circumstances, am i able to calibrate my TV using the above mentioned settings? Do I need to configure my CP3 to match those settings? As i need to plug the HDMI cable into port that my device is using, do i need to set my TV to the same video signal color space? It's currently set to BT.2020. As for the color adjustment, i have enabled the temperature to Multi point (20p).
I hope someone is able to guide me as repeated attempts to properly calibrate my TV ends up in failure.
Posted: Sat Oct 22, 2022 4:09 pm    Post subject:
Hi!
For questions around using ChromaPure, best you email them directly at Support@ChromaPure.com with your order details and other info. They will then be able to assist.
Take a look at our step by step guide as well: https://www.curtpalme.com/forum_archived/viewtopic.php@t=35322.html
