poen
| Posted: Fri Jan 01, 2021 9:08 pm Post subject: Sony 1292 - image shifting |
Hello all,
My Sony 1292 is shifting its picture either with or with no source every 4-5 seconds around the edges from left to right.
Could this be caused by a bad EA board? (the small left board on the PSU) ?
| Posted: Sat Jan 02, 2021 2:05 pm Post subject: |
Perhaps check for loose connection around the horizontal deflection connectors?
poen
| Posted: Sat Jan 02, 2021 2:27 pm Post subject: |
| gjaky wrote: | | Perhaps check for loose connection around the horizontal deflection connectors? |
Hi Gjaky, where exactly would I find the horizontal deflection connectors? Want to be sure I am checking the right things here:)
Thanks for helping!
poen
| Posted: Sat Jan 02, 2021 6:42 pm Post subject: |
| poen wrote: | | gjaky wrote: | | Perhaps check for loose connection around the horizontal deflection connectors? |
Thanks for helping! |
Dear Gjaky,
I doublechecked, wiggled, pushed every connection visible including a bit of turning and twisting on the adjusters / yokes on the tubes- this indeed fixed the shaking issue.
However! now I have something new, the test pattern lines are not so sharp anymore, what could this be?
Really seems this machine wants me to stop working on it:(
| Posted: Mon Jan 04, 2021 9:43 pm Post subject: |
| poen wrote: |
A picture often tells more than a thousand words
