1080p24
Flash
Posted: Mon Feb 24, 2020 10:33 am    Post subject: 1080p24
If I connect a BluRay source at 1080p24, will the Moome card be capable of handling that correctly? Will it refresh properly at 72Hz?
Posted: Mon Feb 24, 2020 2:46 pm    Post subject:
No. The moome card does not convert refresh rate nor does it scale the resolution up or down. Whatever resolution/refresh rate you feed the card is passed through.
You need to set the source to whatever refresh rate (and resolution) you want to see.
If you can't, you need a full blown video processor. Example: http://www.curtpalme.com/Radiance.shtm
