lazerdust
| Posted: Mon Jan 22, 2018 12:16 am Post subject: Sony G70 error 38? |
Hello, I am new to the world of CRT projectors and I picked one up a bit ago. It turns on but I get an error 38 after a minute of it turning on. Sometimes I can get it to a calibration menu but then it shuts off.
What do you think the problem is and what will it cost me to fix?
cheers, lazerdust
| Posted: Mon Jan 22, 2018 12:32 am Post subject: |
In the dozens of G70s I've worked on, I've never had a 38 error code. It's an error in one of the CRTs:
http://www.curtpalme.com/docs/SonyG70_Error_Codes.pdf
What I would do is pull off the CRT socket on each tube one at a time, and fire up with the remaining two. See if you can get two of the tubes to fire up, and we can narrow it down after you try that.
Thanks!
