thewolfman
| Posted: Tue Jan 16, 2018 2:43 am Post subject: Reviving the 'ol Marquee |
Ok, so the lowest amount of bords to power up the fans is: LVPS+HVPS+CLM, right?
| Posted: Tue Jan 16, 2018 6:47 am Post subject: Re: Reviving the 'ol Marquee |
| thewolfman wrote: | | Ok, so the lowest amount of bords to power up the fans is: LVPS+HVPS+CLM, right? |
First, are you still dealing with that 9518 VDC model?
| Posted: Tue Jan 16, 2018 8:44 am Post subject: Re: Reviving the 'ol Marquee |
You don't even need the HVPS, although it makes no difference as HV generation will be disabled due to the scan fail error.
thewolfman
| Posted: Tue Jan 16, 2018 1:56 pm Post subject: Re: Reviving the 'ol Marquee |
| mp20748 wrote: | | thewolfman wrote: | | Ok, so the lowest amount of bords to power up the fans is: LVPS+HVPS+CLM, right? |
First, are you still dealing with that 9518 VDC model? |
Yes, it same VDC as Before. I have parts to cover most of 3rd projektor ultras. I will test soon and see what happens, Thanks.
thewolfman
| Posted: Tue Jan 16, 2018 1:58 pm Post subject: Re: Reviving the 'ol Marquee |
| gjaky wrote: | | thewolfman wrote: | | Ok, so the lowest amount of bords to power up the fans is: LVPS+HVPS+CLM, right? |
You don't even need the HVPS, although it makes no difference as HV generation will be disabled due to the scan fail error. |
Thanks, then I'll start so and see.
| Posted: Tue Jan 16, 2018 2:22 pm Post subject: Re: Reviving the 'ol Marquee |
| thewolfman wrote: |
Yes, it same VDC as Before. I have parts to cover most of 3rd projektor ultras. I will test soon and see what happens, Thanks. |
OK, that's the same one you've already spent countless hours on before. So try and remember where you left off and post here in this thread when you're ready to start again.
The boards in it will work in previous Marquees, but some older or earlier boards won't work in the 9518. Even when working, there are still some bugs in that model.
Anyway, get back when you're starting this up again.
thewolfman
| Posted: Fri Jan 19, 2018 1:11 am Post subject: Re: Reviving the 'ol Marquee |
Anyway, get back when you're starting this up again. |
Sure will. I watched IT last night but didn't like it very much but the feel of it was like seeing ET all over again. I enjoy Movies like that. The Goonies feel of it and actually seeing it again tonight.
I do wonder if I made an error esambling the last set Ultras.. not to mention the remote issue. The odd thing is that the remote issue started before I changhed the boards and got to the point where I had to go closer and closer to the reciver to get it to work. Shortly there after the remote gave up completly.. but 3 remotes of which 2 are the same still don't matter. Strange.
