Screen went blank
rayngusa
Posted: Wed Dec 13, 2017 2:38 am    Post subject: Screen went blank
Hi watching movie on my Sony G70 last night and after playing about an hour screen went blank and says no input. I got this on Videogon about 5 years ago and it's been working great. Can it be the input card? Today started it up it was fine for about 20 mins and did the same. Can anyone help?
Ray
Posted: Wed Dec 13, 2017 5:52 am    Post subject:
If you can use another input you might be able to determine if its the source device or the Moome Card.
Posted: Wed Dec 13, 2017 1:30 pm    Post subject:
Do the internal menus work?
rayngusa
Posted: Wed Dec 13, 2017 2:40 pm    Post subject:
Yes,
Posted: Wed Dec 13, 2017 2:44 pm    Post subject:
Ok.
I don't know the internal architecture of the G70, but since the internal menus work you know it's not something near the end of the signal chain (tubes/drives/etc) but is likely closer to the input side. Like km987654 mentioned, if you have another input to try that would be a good bet.
WHat are you feeding the projector with and how is it connected to the projector? In other words, what type of input are you using now? And what do you have available?
Hopefully some Sony G70 experts will chime in too... (I've never used a Sony G70).
Good luck!
rayngusa
Posted: Wed Dec 13, 2017 2:56 pm    Post subject:
Ok.
Good luck!
Hi I'm using PJI HD Signal Processor converting BCN to HDMI along with Lumgen. They seem to be working fine. Also the second time I turned it on it worked for another 20 mins before going blank and audio was still working.
Ray
Posted: Wed Dec 13, 2017 3:07 pm    Post subject:
How do you know the PJIHD and Lumagen video processor work fine? Did you try hooking everything up as is to a different HDMI capable display? (Like a flat panel TV)
rayngusa
Posted: Wed Dec 13, 2017 4:05 pm    Post subject:
Don't know for sure. Just a guess. But I'll test it today. Thanks for the advice.
Ray
rayngusa
Posted: Wed Dec 13, 2017 4:12 pm    Post subject:
Ray
I'll try to connect with a new set of cables too.
Ray
