Barco 909 G2 problem on blue tube
ElTopo
Posted: Sat Dec 02, 2017 2:49 pm    Post subject: Barco 909 G2 problem on blue tube
Hi guys,
i have a Barco 909 which seems to have some G2 issue on the blue tube.
Meaning that with full brightness down i still have a glowing backlight.
How can G2 be set on the 909 ?
thanks in advance
ElTopo
Barco Cine 9 the one and only
Hulio
Posted: Sat Dec 02, 2017 3:46 pm    Post subject:
No G2 adjustments in BR909.
Move the RGB end-stage to other tube to see if problem follows.
Hulio
Posted: Sat Dec 02, 2017 4:06 pm    Post subject:
Right, before you do that, try another SMPS2+G2 board. It takes less time than swapping neckboards.
The G2 voltage is generated there....
