Seagate HDD repair
Posted: Sun Feb 25, 2007 2:59 pm    Post subject: Seagate HDD repair
I had my seagate barracuda 7200.8 250GB. HDD bite the dust last night; One of the pins on the controller board became bent and then fell out, my question is can the controller boards from other seagate drives be used on mine to fix it. If possible I'd like to get a 40GB. seagate drive and swap off the controller board. Looking at cost this looks like a better idea $30 vs. $100
Erik Very Happy
Posted: Sun Feb 25, 2007 4:55 pm    Post subject:
I've done this but only with same/same hard drives. Never tried it with different models
Jaric00n
Posted: Sun Feb 25, 2007 9:24 pm    Post subject:
Zebu
it will not work
the bios on the controller will not be able to recognize # of platters/heads
Tried this with so WD drive with important data...
bought another exact same drive ..swapped it...and voila...saved all the data ...
Joust
TV/Projector: Marquee 8501LC
Posted: Mon Feb 26, 2007 1:59 am    Post subject: Re: Seagate HDD repair
Erik Very Happy
is the bent pin a symptom or a cause?
if its a symptom of something else. yeah look for another similar drive. if it is teh root cause, fix it.
jordan
Posted: Wed Mar 26, 2008 5:53 am    Post subject:
Elaine Benes
Posted: Wed Mar 26, 2008 12:50 pm    Post subject:
I've seen just controller boards for sale on ebay for quite a bit less than the full drive.
MikeEby
Posted: Sat Mar 29, 2008 8:09 pm    Post subject:
Plus you could recover the data, in many cases that's more important then the cost of the drive.
Posted: Sat Mar 29, 2008 9:57 pm    Post subject:
My wife has a Maxtor 3200 drive that just bit the big one. And natch, she never backed it up. The USB connection still works, but the systems never recognize it as a drive. I'm guessing the controller bit it. Hadn't thought about swapping in another controller. Maybe I'll open it up and see if I can swap it out myself.
And we're getting two 1TB network drives to start backing things up religiously. Smile
Posted: Sun Mar 30, 2008 2:24 am    Post subject:
Hey, that was a LOT easier than I expected. Once I finally pried the @#$# case open (it will never close again, but I don't care), I just removed the USB interface board, plugged the drive into a PC, and shazam! There's all our data. Apparently it was just the USB board that went bad. That's about the LAST thing I would have expected, especially since Windows recognized it as a Maxtor 3200 when you plugged it in!
The data is all being copied over to another drive now. *phew* Smile
Phil Smith
Posted: Thu Apr 03, 2008 11:11 pm    Post subject:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=330223852306
jmcmahon7
Posted: Sun May 04, 2008 12:52 am    Post subject:
Looks like you are sorted, but ill add this to the thread anyway.
Changing logic boards can be a crapshoot and you can actually loose data. The prospective board must the be same board rev and same frmware rev. If you can nail that then you are in good shape (things can still go wrong!), otherwise its tricky and pretty risky. If you dont value your data that much, ie its not of significant financial or sentimental value, then "guessing" the logic board is one way to go.
If you break a pin on the HD connector you can always stick a longer pin in the IDE connector that protures just long enough to touch the metal in the drive. Needless to say, this is a tempaorary workaround, just to get your data off there.
HTH
