1x4 HDMI Splitter Help?
silv55
Posted: Tue May 16, 2017 1:22 pm    Post subject: 1x4 HDMI Splitter Help?
HI guys i need to buy a reliable 4 Ports HDMI 1x4 Powered Splitter Ver 1.3 Certified for Full HD 1080P,
so my setup will be Output HDMI signal from MINIX NEO U9-H, 64-bit Octa-Core Media Hub for Android,to the 1x4 Sp-liter and connect to a 1080P Led VIZIO TV and a 1080P Phillips LCD TV and then connect also on the third port a 1080P HDMI to Composite video converter adapter;Tendak 1080P HDMI to AV 3RCA CVBs Composite Video Audio Converter Adapter,that i want to connect to my Old tube TVs that will be connected to this 1080P converter to Composite video,then from the RCA composite adapter i send the signal to a RF {radio frequency} converter throughout coaxial cable to the whole house.
At present time i have a manual push button switch 1x2 connected with 1 TV and the 1080P to Composite video adapter and it's working great but i have to switch outputs manually every time i want to watch another TV, wish you guys build one like this 1x3 push button manually,i wouldn't mind at all see pic. Sewell Direct Ibis - 2x1 or 1x2 HDMI Bi-Directional Switch with HDCP Passthrough, 3D and 1080p Support,any insight on this from you experts,thanks
Posted: Tue May 16, 2017 2:10 pm    Post subject:
All that in one box will be expensive. I suggest you get something like a straight HDMI 1x8 splitter and run individual HDMI-to-whatever converters off of that. It'll cost you less and you get what you NEED.
silv55
Posted: Wed May 17, 2017 12:02 am    Post subject:
Thanks i just ordered this one, hope it'll work ?if not i'll return it like the previous one,amazon is five stars with returns.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Posted: Wed May 17, 2017 2:00 am    Post subject:
Bad link, try it again?
silv55
Posted: Wed May 17, 2017 6:39 pm    Post subject:
Thanks cmjohnson;
https://www.amazon.com/gp/product/B00UNX0PJU/ref=as_li_ss_tl?ie=UTF8&psc=1&linkCode=ll1&tag=curtpalmecrtp-20&linkId=fbc2d7f75dc10328c71c2e169d555bba
