lydmann
| Posted: Sat Apr 15, 2017 6:54 pm Post subject: shortcut in tube, anything to do? |
We manage to make a shortcut in the tube. So it is very bright and you can see retrace lines in picture. Any tricks to repair the damage?
I found this.. but I am unsure if it relevant .
https://www.repairfaq.org/REPAIR/F_monfaqa.html
| Posted: Sat Apr 15, 2017 8:02 pm Post subject: |
What tube?
| Posted: Sat Apr 15, 2017 8:16 pm Post subject: |
Some Sencore CRT analyzers/restorers have a "clear G2 short" function.
The presence of retrace lines indicates that you have a G2 short, probably to the cathode.
lydmann
| Posted: Sat Apr 15, 2017 8:57 pm Post subject: |
p22-30 green tube
| Posted: Sat Apr 15, 2017 9:50 pm Post subject: |
H-K shorts in a front projection tube usually can't be cleared, so I think you need to replace it. I know I killed the filament in an NEC XG that I tried to do it to years ago.
| Posted: Sun Apr 16, 2017 1:05 pm Post subject: |
If the tube is otherwise in good condition, for a H-K short I'd experiment with isolated DC-DC power supllies for the filament supply instead, that is less risky.
barclay66
| Posted: Sun Apr 16, 2017 5:24 pm Post subject: |
I managed repairing several tubes with shorts using my Müter crt analyzer/restorer (german brand). You could send it to me if you run out of options. It can't get worse after all...
Regards,
barclay66
