Sony G70 FullHd V2 1.3 Green Screen Help
spankedmonkey
Posted: Fri Mar 24, 2017 3:36 am    Post subject: Sony G70 FullHd V2 1.3 Green Screen Help
I have a G70 with Moome FullHD V2 1.3 card feeding multiple sources through a Denon AVP A1HDCI. Sources are HD-DVD, Denon 4010 Blu Ray, DirecTV HD, D-VHS, and PS4. I've had no problem until recently when signal is fed from the PS4 and D-VHS the picture is green. I've tried feeding these two sources through the same inputs on the AVP that works fine with HD-DVD and Denon Blu Ray Player but the picture is still green. Switched between RGB and YCBR in the AVP settings but no fix. Any advice on this one?
Knowing is not enough you must apply. Willing is not enough you must do. -Bruce Lee
spankedmonkey
Posted: Thu Dec 07, 2017 1:03 pm    Post subject:
So I meant to follow up with this some time ago. After searching I found that pressing the number 4 button on the Moome Card remote corrects the signal input problem. Loving my G70 VR, feeding all sources mentioned problem free. Very Happy
Posted: Thu Dec 07, 2017 4:36 pm    Post subject:
The magic number is 4. Thanks for the update. Does the manual actually tell you what that does?
spankedmonkey
Posted: Thu Dec 07, 2017 11:39 pm    Post subject:
Literally no mention of it in the manual. In fact just functions of input, gamma, and output range 0-255/16-235 listed via the remote. Kind of dug up this info. after a lengthy search.
