Harmony remotes and Marquee projectors
bpdski
Posted: Wed Mar 22, 2017 10:50 am    Post subject: Harmony remotes and Marquee projectors
Hey, so I bought a Harmony 650 remote hoping it would control all my components. It actually knows about my 9500 and allows me to set that up but it doesn't work right. I've since read on here that the Marquees use a higher frequency IR that the cheaper Harmony remotes don't support.
Does anyone know what the least expensive Harmony remote is that will work with my 9500? I'm open to suggestions of other brands as well, I just want to find something that I can use with all of my equipment and has the ability to learn custom codes. I was hoping to keep the cost under $100.
Brian
Posted: Wed Mar 22, 2017 11:39 am    Post subject:
Say Brian
You want to find one that handles extended command strings. The Marquee power on command, and standby command, require 1 or 2 second
blasts.
bpdski
Posted: Wed Mar 22, 2017 1:48 pm    Post subject:
Thanks Tim. The other commands like contrast, brightness, etc. don't seem to work either with this remote.
Posted: Wed Mar 22, 2017 2:13 pm    Post subject:
Right
The newer Marquees use a 336khz IR subcarrier.
Posted: Sat Mar 25, 2017 4:05 pm    Post subject:
Hello
I'm told the Phillips Pronto works well, TSU3000 among others
bpdski
Posted: Sun Mar 26, 2017 10:35 pm    Post subject:
Thanks Tim. I'm trying to see if I can find a good, used Harmony One right now, looks like a good remote to use.
Brian
bpdski
Posted: Fri Apr 14, 2017 10:55 am    Post subject:
I found a Harmony One which I like, but it too doesn't work unless you point it at the receiver. So, I extended the wire on the IR receiver and put it with the rest of my AV equipment in a cabinet near the screen and that seems to work ok.
