Theater design?
deronmoped
Posted: Sat Oct 15, 2016 3:33 am    Post subject: Theater design?
I'm in the process of rebuilding my downstairs theater, so things are going to be torn apart far enough where I will be able to access the guts of the walls, ceiling and floor. What should I be looking at in the way of CRT placement, wires, screen... I did it once before with a ceiling mounted PJ. Is there a cool way of putting the PJ on the floor?
Posted: Sat Oct 15, 2016 11:00 am    Post subject:
Hello
If on the floor a low table should do it. Consider cutting a channel in the floor to hide wires.
Posted: Sat Oct 15, 2016 1:54 pm    Post subject:
Check out the 'gallery' on the main site, it should give you some ideas.
I'd trench a conduit in, maybe 2" in diameter. What happens in 5 years from now when HDMI goes by the wayside, and optical is the way to go? (I'm guessing only here). With a conduit, you can add/remove anything.
Posted: Sat Oct 15, 2016 5:25 pm    Post subject:
I don't know of a cool way to put the pj on the floor. You could put it behind the seating. By pointing the pj vertically and bouncing the image off a first surface mirror, you can keep it out of the way.
Posted: Sat Oct 15, 2016 5:36 pm    Post subject:
Yeah
But the room will look like crap with a mirror unless it's up near the ceiling and concealed some.
deronmoped
Posted: Sun Oct 16, 2016 2:40 am    Post subject:
A mirror really opens a lot of options, placement, throw distance. Will they degrade the image. That was one thing I was worried about, having enough distance to the screen.
Yeah, some pipes both ceiling and floor connecting the entertainment center/HTPC with the PJ would be smart.
One idea was to place a seat on top the PJ. On a platform of course.
What about storage, I will have several extra PJ's that will need a good home, if not a spot so they can project. One on the ceiling, one on the floor for the main screen. A second screen on a different wall, maybe.
deronmoped
Posted: Sun Oct 16, 2016 2:42 am    Post subject:
What about a PJ in a different room, upstairs, projecting down to a mirror, then to the screen? Noise from the PJ would be a non issue then. Interesting...
Posted: Sun Oct 16, 2016 7:02 am    Post subject:
Guys
I have worked with the mylar plastic mirrors many times and they are cheap and light weight but they are never perfectly flat and can lead to focus issues.
Glass first surface mirrors show up now and then when rear/mirror CRT installations get torn out. A new one is rather expensive, if you can find a new one.
BobNelson
Posted: Sun Oct 16, 2016 2:19 pm    Post subject: Coffee Table
Put the projector under a custom made coffee table. Nobody even knows you have one when you have a pull down screen. Very Happy
Martinized and Parkerized 9500LC
deronmoped
Posted: Sun Oct 16, 2016 3:15 pm    Post subject:
Tim in Phoenix wrote:
Guys
What about stripping the paint off a mirror, to reveal the first surface. I watched a youtube video and it looks pretty straight forward. What about PJ TV's in the cabinet, do they use mirrors?
Posted: Sun Oct 16, 2016 3:29 pm    Post subject:
Too bad, I just junked my Barco retro 808. It had a HUGE optical grade mirror in it, and there was zero distortion with it.
loudmouse2
Posted: Sun Oct 16, 2016 6:03 pm    Post subject:
The big old rear projector TVs usually have good mirrors in them and there's always a bunch of free ones on craigslist.
At one time I was thinking of putting the old Sony 1020 PJ under the bed and projecting to the ceiling above bounced off a mirror, but I was worried about creating a fire hazard so never did it. I had one of those horrible resolution toy PJ's mounted on a headboard but image quality and fan noise were problems. Do they make LED projectors without a fan these days?
Posted: Sun Oct 16, 2016 7:01 pm    Post subject:
RPTVs have first surface mirrors as was mentioned.
While the coffee table method is ok, the screen size is limited. As a point of reference, at a 10' seating distance the pj would be around 7' from the screen. That leaves you around a 65" screen.
BobNelson
Posted: Sun Oct 16, 2016 8:02 pm    Post subject: Screen
Mine is 60" x 80". Running HD material at 16 x 9 = 92" diagonal. Very Happy
Posted: Mon Oct 17, 2016 1:34 am    Post subject:
How far back do you sit?
deronmoped
Posted: Mon Oct 17, 2016 3:15 am    Post subject:
That is why I was thinking of having the seating over the top of the PJ. Build a platform to enclose the PJ and have the seats on top of the platform.
Posted: Mon Oct 17, 2016 3:26 am    Post subject:
If you put the PJ on the floor, the very best possible viewing spot will not be available to you, because that's the projector's location.
