| Posted: Wed Oct 12, 2016 3:33 am Post subject: G90 setup with Moome V2 HDMI full HD intput card, SOLVED. |
Ok, I've reached the point with my new (to me) G90 that I'm ready to connect a blu-ray player to the Moome HDMI full HD V2 (non-3D) input card.
Blu-ray player is an older Sony model. It does allow 24FPS output and allows the output over HDMI to be set to RGB 0-255 or 15-240 or to be set to component. YpRbR, or whatever it is.
So please tell me how to set this up to work properly with the G90. I don't have the Moome manual as I didn't get that with this projector, and I have tried (obviously not!) everything in the G90's menus even in service mode.
I know it can be done and I would probably find it eventually, but I'm hoping someone will save me the time spent trying combinations until I find the right one.
Where I'm at now is I can either get a black and white picture or I can get a picture that is all green or all magenta. Which is just what you should get when either the PJ or the source is set to component and the other is set to RGB.
| Posted: Wed Oct 12, 2016 3:39 am Post subject: |
Is that the moome card with one HDMI and one component or two HDMI inputs?
| Posted: Wed Oct 12, 2016 4:22 am Post subject: |
No, it has two HDMI inputs. It's the version just before the 3D compatible version.
I did find the 3D version's manual online. I went through the settings and almost got it but not quite,
so I'm going to try a different player on the off chance that the player has a bad HDMI port. The image just always
seems to be missing all blue channel information.
Both HDMI ports on the Moome card behave the same, so I tend to believe it's not a Moome card problem.
| Posted: Wed Oct 12, 2016 4:52 am Post subject: |
Set the player to 24fps off. HDMI either RGB 0-255 then you need to get the Moome card set to the same. If that doesn't work try 15-235 and set the Moome card the same. Also try unplugging the HDMI cable and plugging it back in. I remember having to do that on one of these cards.
Oh yeah and try switching inputs with the selector switch on the card.
| Posted: Wed Oct 12, 2016 3:03 pm Post subject: |
All those things are done. Still not getting any blue so I'm going to swap out players. That particular player was given to me for free, maybe that's why it was free?
It's a Sony BDP-S300, a first generation unit. Actually I have two of them. I later moved on to a BDP-S470 which although of very cheap construction is much quicker to boot up and load a disc.
| Posted: Wed Oct 12, 2016 4:49 pm Post subject: |
Funny, I also have two SONY BDP-S300's
| Posted: Wed Oct 12, 2016 6:01 pm Post subject: |
I tried the S470 player which is known to be working perfectly and has more output options.
Still the same. Oddly, some WHITE objects do display as white, but any other color always appears as either a shade of green or a shade of pink-magenta.
There IS a picture on the blue tube.
Is it possible that my HDMI cable could be bad but still deliver a picture?
I have a few more tests to make. One of which is to hook up my D810 via its HDMI cable to the HDMI port and see if THAT works,
playing video from the camera.
At that point the only common thread will be the card.
I think I should probably reseat the card. Maybe that's all it is.
| Posted: Wed Oct 12, 2016 7:11 pm Post subject: |
Problem solved. Changed the output of the player to 4:2:2 YcRbR from 4:4:4.
Oddly, switching the output to RGB did NOT help.
Since I don't have the correct manual for this 2010 version Moome card, I'm kind of limited on my knowledge of its capabilities.
Will it do 4:4:4?
I do have a Moome remote. It's for my Marquee HDMI 1.3 card. is it fully compatible with the Sony version HDMI card?
