fritjof-nansen
| Posted: Thu Sep 08, 2016 5:25 pm Post subject: SONY KP-7222 |
Hi Guys,
Need the Pinout for a Sony Projection CRT SD116! Is SD116 compatible with SD130, SD187,07MS Tubes?
It's possible to build in another sockets?
If anyone knows what the Pinout is for a Sony Projection CRT SD116 I would appreciate you sharing it with me. Thanking You in Advance
Robert
| Posted: Thu Sep 08, 2016 5:44 pm Post subject: |
No, it's a totally different tube, and if I remember correctly, the neck is thinner on the SD116.
fritjof-nansen
| Posted: Thu Sep 08, 2016 6:16 pm Post subject: |
Hi Kurt!
Can the Sony Kp-7222 PSE converted so that it can also use 07ms tubes from Sony?
How is it possible to get the jewel alive?
My tubes are consumed and the SD-116 tubes are getting nowhere.
It would be nice if you could help me find a solution.
with friendly greetings from Germany
