Barco 919 Tube Decision
gregstv
Posted: Fri Aug 26, 2016 9:31 pm    Post subject: Barco 919 Tube Decision
Hi guys,
If you had the option of a P19lug or a P22 both in mint condition, which one would you choose, or are that so close it doesn't matter?
Thanks in advance.
ElTopo
Posted: Fri Aug 26, 2016 9:41 pm    Post subject:
P19LUG for HT use.
P22 are known to be used for high refresh rates.
Barco Cine 9 the one and only
Hulio
Posted: Fri Aug 26, 2016 9:59 pm    Post subject:
Yep, go for the LUG. PT22-30 will flicker on less than 96Hz refresh-rates plus, the combination with a green C-element is not ideal for perfect grayscale calibration. The green is kind of lime-yellow.
gregstv
Posted: Fri Aug 26, 2016 10:07 pm    Post subject:
Thanks guys, The Lug it is.
lydmann
Posted: Sun Sep 11, 2016 7:19 pm    Post subject:
Wrong info. pt22- 20 will flicker, not pt22-30. Pt22-30 is also almost spot on on rec 709 standarden
gregstv
Posted: Sun Sep 11, 2016 8:27 pm    Post subject:
I have a bran new green LUG from Barco. I have been hanging onto it and not using it for some reason.
I decided its time to use it and enjoy. Its now fitted to the 919 with a green C Element.
Posted: Mon Sep 12, 2016 6:40 am    Post subject:
Your impressions when you get this running. Thumbs Up
