Barco no image
tanwn1
Posted: Thu Jan 21, 2016 12:55 am    Post subject: Barco no image
barco 909 powers up, all green leds no red , no CRT crackle, tube filament not lit. Quad or splitter?
Posted: Thu Jan 21, 2016 7:12 am    Post subject:
Tube filament usually means a SMPS issue. No red led on EHT board I would look at the scan fail circuit as it could be vertical board, horizontal board, deflection coils, quad or splitter. If you have swapped out the boards and its still the same then look at the splitter but no heater you need to look at the SMPS.
tanwn1
Posted: Thu Jan 21, 2016 7:34 am    Post subject:
If proj on standby should crt filament be lit?
dummyload
Posted: Thu Jan 21, 2016 7:42 am    Post subject:
No filament in stby . Only the smps subboard +9v is active ,main smps , smps2 and pcf are of in stby.
tanwn1
Posted: Thu Jan 21, 2016 8:01 am    Post subject:
Ok so if quad or splitter is not working, filament should stay lit when poser on right? So no filament means smps issue only? Or is there other possibility that cause no filament.
tanwn1
Posted: Thu Jan 21, 2016 10:24 am    Post subject:
Ok manage to get filament lit now with change of smps. But did not hear crt crackle no image. Guess its now left to either splitter or quad right?
redfox001
Posted: Thu Jan 21, 2016 11:00 am    Post subject:
If there is no red led on the EHT I guess it is the EHT. Check the fuse.
tanwn1
Posted: Thu Jan 21, 2016 12:35 pm    Post subject:
ok, check EHT and indeed fuse is blown, replace and still blown. Change to another EHT and now I manage to get CRT tube to light up and it display BARCO logo but I can't get any image when source is connected. What should I change out now? Controller board?
redfox001
Posted: Thu Jan 21, 2016 1:23 pm    Post subject:
Look at the switcher. Do you have the moome internal?
tanwn1
Posted: Thu Jan 21, 2016 11:12 pm    Post subject:
I am using Moome ext v3, how does the switcher look like? Is it the board beside rgd driver?
redfox001
Posted: Thu Jan 21, 2016 11:24 pm    Post subject:
Yes.
redfox001
Posted: Thu Jan 21, 2016 11:31 pm    Post subject:
Can you display the menu's?
tanwn1
Posted: Fri Jan 22, 2016 3:23 pm    Post subject:
Rejoice, barco 909 is finally working!!! I removed port 3 board and limo board and joined jumper cable, image came back but was jumpy, swopped vertical deflection board, and now picture is stable as a rock. Thanks redfox001
