Anybody seen this problem before - Marquee
Posted: Sat Jan 09, 2016 12:08 pm    Post subject: Anybody seen this problem before - Marquee
It has already been isolated to the CLM. It's a new CLM. I'm hoping for a fix.
It's not there on initial projector turn on, but after or more minutes, it degrades into doing the zaggies.
upload a picture
Posted: Sat Jan 09, 2016 12:30 pm    Post subject:
Since you already circled to the CLM, I'd try to swap the DPB with an other known working CLM's DPB.
redfox001
Posted: Sat Jan 09, 2016 12:58 pm    Post subject:
I noticed that I got zaggies when I went to 72Hz. At 60Hz they where gone. But mine where only a very little.
I tried swapping the board on the horizontal deflection with no change.
After warm up it becomes less in my case.
Tried two CLM and would be interested in a fix too. Because of the temperature change it might be caps?
Posted: Sat Jan 09, 2016 1:35 pm    Post subject:
That was it Gjaky... and it makes sense that the problem should have been the DPB. I should have tried that already..javascript:emoticon('Embarassed')
Anway, that noise is completely gone. Now, I'll need to track down the other one. Which is a bunch of noise lines moving up and down the screen.
Thumbs Up Thumbs Up
redfox001
Posted: Sat Jan 09, 2016 1:42 pm    Post subject:
Do you happen to know what causes this?
It is not on the internal testpatterns. It is only on 72Hz and not solvable with timings.
Posted: Sun Jan 17, 2016 4:33 pm    Post subject:
If timings don't help, I've seen that many times caused by a bad HDM board on Marquee.
redfox001
Posted: Sun Jan 17, 2016 4:51 pm    Post subject:
Better sync timings did help but there are still a very little zaggies. I will check the HDM. Thanks.
Posted: Sun Jan 17, 2016 10:19 pm    Post subject:
I've had a few clients with trouble like this...
The last one I saw though was when I met Curt at Tim's place in Arizona. One of Tim's two blend projectors started doing the "zaggies." Curt and Tim had no idea, but I was like, "I've seen this with HDM's before." Sure enough it was on the HDM.
I couldn't believe that I knew a quick Marquee fix that Tim and Curt didn't already know Mr. Green
I'll be curious about yours.
Posted: Mon Jan 18, 2016 12:43 pm    Post subject:
I had this same problem, even after I solved the problem shown in the screenshots when I started this thread. But with me of course, I don't have the option of changing the timings. So I fired up the test bed, pull out the extender card rig and me and the scope went to work.
I'll post in a few what all I've found, but for sure I no longer have either problem now. I'll post back what I've found in a few...
haireez
Posted: Mon Mar 28, 2016 2:37 pm    Post subject:
Mike,
Any updates on this?
2 White Vision 1
Posted: Mon Mar 28, 2016 6:21 pm    Post subject:
haireez wrote:
Mike,
Yes, but for now, replace C12 on the CLM with either a 10uf electrolytic or 22 to 33uf tant. You also need to put a 0.1uf in parallel with the cap. That cap is the secondary of a 12 volt regulator right near it. That 12 volt supply is critical to that problem.
There are also several other areas that could use attention, but for now that's what I have time to address, and is one of the two main areas for clean sweep performance. That cap was the problem when using my ver 5.5 DPB
