gregstv
| Posted: Sat Jan 02, 2016 8:22 am Post subject: Blue coolant |
Hi Guys,
I had a brain fart about blue defocusing to get the correct gray scale tracking.
Digital projectors use a polarizer to intensify the blue light to get good white balance. I was thinking if the blue coolant was tinted you wouldn't need as much blue defocus. Has anyone ever tried tinting the blue coolant with blue dye?
| Posted: Sat Jan 02, 2016 8:40 am Post subject: |
With blue dye you can only (fine)tune the spectra of the light. The purpose of blue defocus is to get more blue output the two are not the same.
gregstv
| Posted: Sat Jan 02, 2016 9:00 am Post subject: |
I am doing the red and green and thought I would have a go at the blue. Sounds like its probably not worth it.
Greg.
| Posted: Sat Jan 02, 2016 9:17 am Post subject: |
In fact it would make the thing worse. With color filtering you actually loose light output, so adding a blue filter would cut blue output even further. On the other hand blue filtering is not even needed because the primary clolor coordinates of the blue phosphor are spot on according to REC.709 color space.
| Posted: Sat Jan 02, 2016 8:14 pm Post subject: |
| gregstv wrote: | Thanks,
Greg. |
Wait!!! You have an LC unit correct? You can not add dye to curved LC chambers, the outer edges will have
more "color" to go through than the center. you'll have a bright spot right in the center.
| Posted: Sat Jan 02, 2016 8:17 pm Post subject: |
Nashou, I think he has SEOS 808s units with AC lenses.
| Posted: Sun Jan 03, 2016 12:14 am Post subject: |
Yeah, the purpose of dye (or colored C-elements or whatever) is to adjust the spectrum. The phosphor doesn't match the correct CIE coordinates for Red & Green so the filtering shifts it a bit and improves the color accuracy. Blue phosphor is already really close to the correct CIE value so you don't need to filter blue. See e.g. my post on Calcolor filters.
And you also don't WANT to filter blue, because blue phosphor doesn't produce enough light already. The purpose of the blue defocus is to get more light out of the tube. If you have a sharply-focused blue, that small dot of phosphor can't produce enough light, and your color balance is off. If you smear the focus a bit (electrical focus, not optical), that small dot now covers a larger area. More area = more phosphor = more light, so that helps to boost the blue level for proper color balance. Fortunately your eye can't focus very well on blue, so you don't notice the defocused blue unless you look at something like white text on a black background. See e.g. this post and this post if you want lots more explanation.
gregstv
| Posted: Sun Jan 03, 2016 12:50 am Post subject: |
Thanks for the information. Yes its a SEOS AC 808s
Its is only white text ( sub-titles) that shows up the defocus. I will leave good enough alone and go back to looking at modding the VNB.
Greg.
| Posted: Sun Jan 03, 2016 8:52 am Post subject: |
A few years ago I "invented" the reddish subtitles, if you can set the color of the subtitles it is really worth it. White subtitles on screeen always decreasing the interscene contrast, by lighting up the room and by bouncing in the AC system. Using reddish-purple subtitles suffer far less from these effects. The red has very low luminence, still easy to read, just a tip.
| Posted: Sun Jan 03, 2016 3:39 pm Post subject: |
That's a cool idea! How did you change just the subtitles?
