Video bars
larryp
Posted: Wed Dec 30, 2015 10:40 pm    Post subject: Video bars
When using my vcr I have horizontal lines that float in the picture. they don't stop. Picture is fine on just the projecture
Any idea how to get rid of them?[/s] I have everything connected securely. No idea what's causing it Thank You
Posted: Wed Dec 30, 2015 10:59 pm    Post subject:
Disconnect the cable input from the VCR and see if a VHS tape shows the lines.
larryp
Posted: Thu Dec 31, 2015 6:20 pm    Post subject:
It only shows up when Direct tv runs thru the vcr.
Posted: Thu Dec 31, 2015 7:42 pm    Post subject:
You need a cable ground isolator. eBay has them, or a good local satellite company should carry them. Insert that into the cable line, problem solved.
larryp
Posted: Thu Dec 31, 2015 10:37 pm    Post subject:
Thanks Curt, I'll order one.
larryp
Posted: Wed Jan 06, 2016 6:32 pm    Post subject:
Well I bought a cable ground isolator. I hooked it to the Direct tv cable, then to the Direct tv box.
I don't get a picture and it says "searching for signal"
Plug the cable in by itself & it works fine??? I don't know
Posted: Wed Jan 06, 2016 6:39 pm    Post subject:
Is Direct TV satellite or cable? If satellite, then yes, one of those won't work. Call DirectTV and tell them that you need to ground isolate the audio and video signals coming in from the receiver, and see if they have a solution. You'll need to talk to a tech, not their first line tech support people.
larryp
Posted: Wed Jan 06, 2016 9:53 pm    Post subject:
It's Diredt TV Satellite, No cable service here that i know of. Ugh, I see hours on the phone coming up!
