Update Lumagen 2041
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products
yin
Posted: Fri Dec 18, 2015 7:14 pm    Post subject: Update Lumagen 2041
2 years ago I bought a Lumage 2041 .I have never updated the software, I read the instruction for downloading.
Still I have a question
If I downlod the top software file do I then have all the older update from the last 2 years or do I have to download all the updates?👀
Posted: Fri Dec 18, 2015 7:21 pm    Post subject:
No. Only the latest (most recent) download is required.
The download is a ZIP file that includes the update and installation instructions.
Older versions are provided for those who may want to stay at a specific version (for whatever reason).
yin
Posted: Sat Dec 19, 2015 10:43 pm    Post subject:
Is there a shortcut to get into the darbee menu with one click?
Posted: Sun Dec 20, 2015 12:01 am    Post subject:
I don't know. I'd suggest checking in the manual to see what the keys/controls are.
yin
Posted: Sun Jan 22, 2017 2:25 pm    Post subject: Update 2041
Today I downloaded the last Software for my radiance 2041,
My problem is when I download Prodution 001316 I do not get a file that I can load up to my 2041!
I also downloaded Utility 1.82. Then I first tried to download out of the Radiance but it does`t work.
Can someone sent me the newest Utility with the software update and which Comm port should used and which baud rate
Posted: Sun Jan 22, 2017 3:08 pm    Post subject:
Hi Yin,
All of the latest updates and software are available on Lumagen's website here:
http://www.lumagen.com/testindex.php?module=support
Nobody would have any newer or different versions. When you download the update there's an included PDF file that has hints and tips on COM ports and even pinouts.
If you continue to have update problems there may be something wrong with the PC or the Lumagen. Your best bet is to contact Lumagen support at support@lumagen.com
Good luck!
yin
Posted: Sun Jan 22, 2017 4:08 pm    Post subject:
Thanks Kai,
I have already figured it out.
When I Update once a year I forget how I did it the year before
I found the problem
yin
Posted: Mon Jan 30, 2017 5:41 am    Post subject:
Hello
can you please tell me what the resolution is when as in pic shown Mode „other",what does that mean?
best regards
 Filesize:  131.86 KB
 Viewed:  10474 Time(s)
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products All times are GMT
