| Posted: Mon Apr 06, 2015 7:34 am Post subject: Least possible lag for a scaler? |
Hi all, i have been using the LIMO PRO that comes with a Barco Cine 9 for my old retro games, which does the job fairly well so it seems.
The issue with a Barco Cine 9 is it doesnt scan to 15.7kHz, so i need to upscan these retro consoles.
Most output 240p at 60Hz or very close to it, some output 59.18Hz, and some are 288p at 50Hz. There is the odd one or two that put out 480i 60Hz or 576i 50Hz.
I want not only the least possible lag, but want no more than 480p or 576p outputs, on the LIMO PRO ive used 1050i 120Hz and 1150i 100Hz modes with some games, but then some games look better that way than others.
The problem with lag is it kills the gaming experience, and makes some games totally unplayable, especially where quick reactions and accurate timing are needed.
I need S-Video input, RGB-S, and possibly also composite video. Only need RGB-S or RGB-HV output.
I have put some of these consoles through the Faroudja scaler in my AVR, and found the lag to be totally unacceptable.
No idea how much lag the LIMO PRO adds, but its not much.
What would be ideal is a scaler that added a black line for every second line making the 240p into 480p without changing the image, which should result in zero lag.
I have looked at the XRGB Mini Framemiester, which looks like a good option, but the XRGB-3 looks to have more inputs and options.
What else is around that will do what i am after?
| Posted: Mon Apr 06, 2015 7:57 am Post subject: |
How about the old fashion farudja line doubler/quadruplers? Have you ever had hands on one of those?
| Posted: Mon Apr 06, 2015 11:27 am Post subject: |
No, but im not sure if theyd be any better than the ones in the AVRs of today.
| Posted: Tue Apr 07, 2015 11:34 pm Post subject: |
Just skimmed Case, but the Radiance line has a "game mode" that provides very little lag that is pretty much undetectable.
If you want to do it on the cheap and you bide your time, you could get an XD that would do the job. Or you could jump for a newer unit and get a great VP for other purposes too.
Even when a Raiance is not in game mode, usually the video is actually ahead of the audio still so the lag is very little.
But you know I am a Lumagen man
| Posted: Wed Apr 08, 2015 12:09 am Post subject: |
Id have no other real good use for it though Craig to warrant the outrageous price they go for new, its a bloody lot of money for what it is!
| Posted: Wed Apr 08, 2015 12:14 am Post subject: |
261751756779
331490493265
Seems like a good toy for that price in my mind. You might be surprised
| Posted: Wed Apr 08, 2015 2:03 am Post subject: |
Ill have a look soon Cheers mate!
| Posted: Wed Apr 08, 2015 2:24 am Post subject: |
I cant view whatever that is, it is coming up as a phone number to my phone
| Posted: Wed Apr 08, 2015 2:31 am Post subject: |
Is there anything that will just add a black line every second line to make the image look identical to the original?
| Posted: Wed Apr 08, 2015 2:47 pm Post subject: |
| CasetheCorvetteman wrote: | | I cant view whatever that is, it is coming up as a phone number to my phone |
They are completed eBay.com listings for RadianceXD's.
jbmeyer13
| Posted: Wed Apr 08, 2015 4:49 pm Post subject: |
| AnalogRocks wrote: | | How about the old fashion farudja line doubler/quadruplers? Have you ever had hands on one of those? |
I used to pipe my Nintendo GameCube through my Faroudja NRS back in the day and it worked great; no lag what so ever. I'd output 1280 x 720 and it looked awesome. I loved playing Metroid Prime and Rogue Squadron
| Posted: Thu Apr 09, 2015 12:11 am Post subject: |
If its changing the res there will always be some lag, id rather not change the res if i could avoid it, which is why i want 480p with every second line black.
| Posted: Thu Apr 09, 2015 12:18 am Post subject: |
I always prefer the original untouched resolution, it looks very good and was designed that way!!
| Posted: Thu Apr 09, 2015 1:35 am Post subject: |
If I ever get the time I'll dig out my doublers and quaduplers. Never enough hours in the day.
| Posted: Thu Apr 09, 2015 3:03 am Post subject: |
There is nothing worse than a 240p image raped into 480p, may as well use an emulator!!
| Posted: Thu Apr 09, 2015 3:18 am Post subject: |
| CasetheCorvetteman wrote: | | I always prefer the original untouched resolution, it looks very good and was designed that way!! |
To be fair though, those original resolutions don't exacly look the same displayed on a monitor that's massively sharper than anything that existed 20-30 years ago. I mean, if you're displaying a game from 1985 on a six-foot screen, you're already straying very far away from how those games were ever originally designed.
| Posted: Thu Apr 09, 2015 4:06 am Post subject: |
| CasetheCorvetteman wrote: | | There is nothing worse than a 240p image raped into 480p, may as well use an emulator!! |
I also have an Extron box that is said to convert 480i into 240p
| Posted: Thu Apr 09, 2015 6:50 am Post subject: |
| ecrabb wrote: | | CasetheCorvetteman wrote: | | I always prefer the original untouched resolution, it looks very good and was designed that way!! |
SC |
I have to dissagree there Crabb, 240p on my XG looks f***en excellent in every sense of the word, even on my 9 foot wide screen.
Its one area where the XG really blows the Cine 9 away.
The biggest screens i saw used in any arcade were 50" 4:3 rear projection, usually Mitsubishi or Toshiba, but a couple used Pioneer and some even used Sony. Most arcade games were 240p 60Hz, which is the resolution used by most home consoles up til the Panasonic 3DO used a 640x480i standard, more than 80% of Sega Saturn games were 240p, with a small few using 480i for NTSC and 576i for the improved PAL versions.
If youve ever played Sega Rally on the Saturn ( in your case it wouldve probably been the rushed US version that lacked the polished graphics of the Japan and PAL versions ) with it upscaled, it looks HORRIBLE, yet in its original 288p 50Hz original format looks pretty damn good for it's day.
The problem with upscaling them is usually looking more blocky than they even did on 240p, which makes them look worse.
The majority of games for current consoles are 720p, but the difference there is the console does the scaling on the fly and makes them look perfectly fine at 1080p.
Scaling 240p to 960p makes them look just like youre playing an emulator, and the whole idea of using genuine original hardware is to have them look perfect, as they did back then.
| Posted: Thu Apr 09, 2015 6:56 am Post subject: |
I know Justin claims to have seen or felt there was no lag scaling his Game Cube to 720p, however Nintendo games often have very good and very forgiving controls, where as some others really need good timing. When they have that, all is smooth and easy.
Need For Speed on 3DO is a prime example of where lag destroys an awesome game, and any 1 on 1 fighting game such as any on the NEO•GEO also suffer greatly due to milliseconds of lag making moves very hard to pull off, and even harder to use at the right time.
gregstv
| Posted: Tue Apr 14, 2015 7:33 am Post subject: |
I did read that the DVDO VP30 is one of the best for games. The least amount of lag.
