Pluge Patterns
AFryia
Posted: Fri Mar 20, 2015 11:13 pm    Post subject: Pluge Patterns
I have a Spears & Munsil Bluray calibration disk 1st gen running on an OPPO83.
I use the pluge 4 bar pattern 1 BTB bar; 1 black; 2%; 4% to set brightness. If I pull up the flashing black bar pattern I can't see any bar flash let alone 17-25, I have to increase brightness. If I return to the pluge pattern I see all bars and the background so obviously the brightness is too high,
Why are the black levels not the same or at least closer on these two patterns.
My Volt Blog
