IceClear AF evaluation
Goto page Previous  1, 2, 3
Posted: Mon Nov 30, 2015 12:19 am    Post subject:
tschaeikaei wrote:
And did you also experience better brightness and sharpness with this stuff, draganm?
Regards, Julian
yes, but the old coolant that came in the tubes I tested was probably not the best of shape. Stuff turns Yellow over time Sad
mc86
Posted: Mon Nov 30, 2015 1:22 am    Post subject:
Drags: Do you mean the IceClear turned yellow over time or that whatever had been in the tubes before had yellowed and therefore you wondered about the test you did, etc..I'm a bit confused.
cheers,
Matt
BTW, my ECP hasn't been running for some time and, now that it is getting cold out and my wife wants to take to hunkering down on the couch, I gotta' troubleshoot and fix it. More likely, I'll get a 2nd chassis running. While I'm doing that, I'll finally do the [phosphor burn-in vs cooling] tests I started prepping for ~18months ago...
Posted: Tue Dec 01, 2015 6:25 pm    Post subject:
original 70% Ethylene glycol /30% Glycerin turns yellow over time, but it might have been absorbing something from the bellows rather than just the liquid itself.
Posted: Sun Feb 14, 2016 2:50 am    Post subject:
The new stuff from MCM ....
http://www.mcmelectronics.com/product/20-6060
tschaeikaei
Posted: Sun Feb 14, 2016 2:00 pm    Post subject:
New stuff? As the market for RPTV and CRT projectors is in fact dead, why would anyone develop this?
I assume it is just something relabeled but quiete interesting to know more about it.
What is it and did anyone try this stuff?
Regards, Julian
Posted: Sun Feb 14, 2016 6:32 pm    Post subject:
While I agree that the market is dead (Strids belief notwithstanding), this probably wasn't "developed". It is most likely a new or recently released product for some other application. Someone thought this could be used in CRTs and repackaged it as such.
Posted: Sun Feb 14, 2016 11:49 pm    Post subject:
if anyone is looking for the original stuff, I still have a 6-pack in sealed bottles. $36. for the box + ship
greg9518lc
Posted: Fri Jun 10, 2016 7:01 pm    Post subject:
http://www.orisonmarketing.com/IceclearAF.html this the best place to buy this or if anyone can offer a better link it is appreciated.
greg9518lc
Posted: Fri Jun 10, 2016 7:14 pm    Post subject:
https://www.amazon.com/gp/aw/d/B00IJZWZTC?pc_redir=T1
This the stuff!
Posted: Fri Jun 10, 2016 8:03 pm    Post subject:
Using Nashou's bellows, and giving them a GOOD cleaning before I installed them back in either 2006 or 2008, (I think it was 2006), I didn't change the regular glycol formulation due to murkiness until just a few months ago. I also treated the exposed aluminum with VHT epoxy, which certainly helped.
One Marquee LC assembly takes 22 ounces as measured in a measuring cup. (Volumetric measurement based on the density of water.) You need 66 total ounces for a set of 3.
Glycol, a gallon can be had on ebay for about 32 dollars.
Glycerin, a quart is about 13 dollars on ebay. And you don't need a quart. A pint is about 7 bucks.
Mix ratio: 1 part glycerin, 4 parts glycol.
So buy 2 quarts of glycol for 16 dollars and 1 pint of glycerin for 7 dollars, and for 23 dollars plus the cost of a can of
VHT black epoxy spray paint, you've got a 10 year solution (pardon the pun) for less than the cost of these things you
are experimenting with.
You'll have about 12 ounces left over, which you might store for...forever.
greg9518lc
Posted: Fri Jun 10, 2016 8:24 pm    Post subject:
Thanks cm went ahead and ordered the 5 gallons for 77.00 as it has tested well and MP
and dragnan vouch for it. I am sure your solution works well but now I have extra for MP when he comes
so he can do his tubes.
Posted: Fri Jun 10, 2016 8:55 pm    Post subject:
For that price, who wouldn't go for it? I thought it was going to be more expensive than mix-your-own glycol solution.
Page 3 of 3
