Another new Turntable, from TEAC?
Posted: Mon Dec 29, 2014 7:37 pm    Post subject: Another new Turntable, from TEAC?
Sure is beautiful, and it comes with a metal platter, which is unheard of for 500 bucks. Usually what you get in the 4-500 range from Sumiko, Rega, and Music Hall is a black painted MDF plinth and MDF platter. Built in USB port is pretty sweet too
Product Description
Product introduction
Belt drive analog turntable. 2 speed 33 1 / 3rpm, 45rpm (EP / LP) playback support. S-shaped tone arm. Phono equalizer amplifier equipped. USB digital output installed. The possible capture a record sound to the PC. audio-technica Inc. VM (MM) type cartridge (AT100E equivalent) included.
Equipped with phono equalizer and a USB output to stylish housing of sliced veneer finish.
Adopt universal type tone arm
In beautiful stylish enclosure of wood stuck to finishing details, MM type cartridge corresponding phono equalizer amplifier and a belt drive analog record player equipped with a USB digital output is TN-350.
Employs a universal type tone arm, and will be able to enjoy replaced with a universal head shell and cartridge of your choice. Phono equalizer amplifier is equipped, you can enjoy the sound of analog record by connecting directly to a system that does not have a phono input. The phono equalizer amplifier, employs a high-precision operational amplifier NJM8080 for made of audio New Japan Radio, and enables high-quality record playback with low distortion.
You can also use a USB digital output, you can be digitally archived on a PC via the sound of analog records.
The TN-350, with a reputation in high reading accuracy audio-technica made MM (VM) type cartridge (AT100E) is included.
The assembled will enjoy immediately clear and highly expressive sound.
TN-350 is a turntable that can taste the new joy of analog audio.Belt drive turntable
The aluminum die-cast platter with a high rotational moment, is driven by the strong DC motor and durable rubber belt of torque, it has achieved a stable rotation.
Stainless steel with improved accuracy by shaving the spindle, the spindle holder using bronze durable, we increase the rotation precision. Enclosure of beautiful multi-layered painted veneer finish of gloss
Was subjected to a multi-layer coating, the casing of the beautiful veneer finish of luster and grain.
Using the high-density MDF, we have to ensure high rigidity.MM type cartridge corresponding phono equalizer built-in amplifier. PHONO in equalizer built-in, it is also connected to the amplifier without the PHONO input, it is possible to enjoy.
In addition, the operational amplifier for PHONO equalizer is adopted high-quality sound operational amplifier NJM8080 for audio made New Japan Radio.
And then restore the delicate analog signal transmitted from the cartridge to the low distortion and loss without the original signal.
USB digital output
The TI Co. A / D converter equipped, can be stored as digital data of CD quality to your computer via USB.
To protect the precious record collection from deterioration, it is possible to enjoy it brought out outside with your existing digital audio player.
Static balance S-shaped tone arm & Universal head shell adopted
By replacement of the head shell and cartridge, is adopted universal type head shell that can pursue the sound of preference. 45,33 1/3 of the 2-speed support
Expanding
LP, playback is possible 33 1/3 rotation of the EP, 2 speed of 45 rpm.
Equipped with arm lifter to facilitate manual operation.
Adopted a strong gold-plated terminals to oxidation to each terminal
Adopted a strong gold-plated terminals to oxidation to head shell connector and RCA terminal.
Also if you want to frequently replace the head shell, prevents oxidation of the terminal.
Audio Technica made MM (VM) type cartridge AT100E included
Includes the audio-technica made VM type cartridge AT100E with a reputation for a high reading accuracy and resolution.
USB port and by-passable built in phono-pre
Posted: Mon Dec 29, 2014 8:10 pm    Post subject:
That looks super nice!!!!
So are you getting one?
Posted: Tue Dec 30, 2014 6:40 pm    Post subject:
no Razz I have a Rega P5 which I practically stole for $850. with RB700 toneram and the outboard power supply. however, I see a nice niche for this table now. If you want something a little nicer than the $180. Orbit your only options were the base offerings from Rega and Sumiko, and those tables are pretty crude and rather ugly. Best you could do is a $400. Project Debut with colored plinth, and you would still need an outboard phono-pre with USB port if your looking to digitize.
After that, Your next step up was to drop over a grand ,so this is a rather nice alternative in terms of all that you get.
paw
Posted: Wed Dec 31, 2014 3:41 am    Post subject:
Slightly off topic. Why an S tone arm as opposed to a straight tone arm? Hey?!?! Why are they called TONE arms instead of just arms?
Aubrey
Posted: Wed Dec 31, 2014 6:27 pm    Post subject:
not OT at all, I don't know why TEAC went to a S arm. Looking at that table, it looks like they're trying to capture that segment of the market that bought the old Denon DP series tables back in the day(they fetch big bucks now). The TEAC looks almost exactly like the old Denon's minus the direct drive and strobe speed indicator. On the Denon's you actually got 2 arms with different mass, there was an extremely low mass arm for certain feather weight cart's and the regular high mass S shaped arm.
I believe the S-arm design is to ease Cartridge alignment. If you look at a straight arm the actual head-shell is pitched at an angle relative to the arm, so the tiny pin leads on the tone-arm and the cartridge are at severe angle to each other.
The tone arm got its name before the age of electronics. It originally served to conduct actual sound waves from a purely mechanical "pickup" called a sound box or reproducer to a so-described "amplifying" horn.
Denon DP80
