Barco Cine 8
Goto page Previous  1, 2, 3 ... 6, 7, 8 ... 25, 26, 27  Next
Posted: Thu Dec 25, 2014 7:19 am    Post subject:
What is the version of control firmware on your control board and RWI chip on both sets?
dentree
TV/Projector: BARCO GRAPHICS 808 BARCO GRAPHICS 801
Posted: Thu Dec 25, 2014 7:27 am    Post subject:
given that there is a 5 year difference in age between the BG 808 and the Cine8 my concern would be compatibility of parts between the two projectors, although essentially the boards look the same I do not know if the later model would have parts/boards which would not be suitable, the only reason I moved (up)? to the Cine 8 was the fact that the tubes on the BG 808 were showing signs of wear and the green tube tended to soften in focus after a few hours running, and the convergence would drift, so I thought a set with brand new tubes would be the go, I suppose one consideration is the fact that the 808 has 13000 on the chassis whereas the Cine has 20000, the only major difference is the tube condition, and of course the drifting convergence on green on the 808.
As attractive a proposition the Cine 8 was with the LIMO facility (which as it turns out is a non event as I am running RGB through a LUMAGEN scaler anyway.
if I were to swap the guns across to the 808 can I use the 808's neckboards or would the current neckboards on the Cine have to go with the tubes?
Beyond it only being a thought at this point in time any other suggestions would be more than welcome
Posted: Thu Dec 25, 2014 7:36 am    Post subject:
Forget tube condition for the moment. Does the other Barco fire up and focus? Is it a BG808?
Posted: Thu Dec 25, 2014 7:53 am    Post subject:
km987654 wrote:
dentree wrote:
thanks for the reply, there could be something in what you say about this projector, as I was reading your post BINGO! this thing shut itself down, opened it up, fired it up and had a look, the RED scan fail light on the G2 diagnostic board is, all the other green are winking away for maybe about 10-15 seconds, then all shut down, quite honestly as much as I want this to work I am almost over it!, apart from the mysterious focus issues, I now have this, is it feasible to swap the horizontal / vertical board from the BG 808, or is that not a good move
Would really appreciate some serious input here, I have gone as far as I can go using all the suggestions to date, and have enjoyed the journey, but now I think I am in uncharted water here.
I must confess that the idea of an XG is sounding attractive........but the reality is this is what I have and somehow have to try to resolve the issues.
Hope your Christmas day has been better than mine! this problem is a present I could well do without!
XGs are a great projector but you would be buying another used projector and you would have no spares. There is no guarantee that another brand of used projector will give you better results. It looks as though you have bought some real issues with this set but you do have another and thats the ticket that you need. Keep moving we will get a resolution.
There is aways that chance Keith, but XGs are typically very reliable, and certainly more stable than a Barco.
Not that a Cine 8 is not a good machine, but so is a 9PG+, and they come with better lenses and WAYYY better convergence.
What really concerns me here, is that this guy sold a set as being perfectly good and working fine, retubed by Curt, and asked a figure that wouldve been astronomical even 5 years ago.
Posted: Thu Dec 25, 2014 8:01 am    Post subject:
Hi Case
Hope you have had a decent Xmas.
This is always a tough call. Money already spent with issues and then jumping ship to another set. I guess he has some decisions to make.
dentree
Posted: Thu Dec 25, 2014 8:57 am    Post subject:
Here are the board numbers from both sets:
Starting in both cases I have identified boards 1 & 2 by name which I have called 1 & 2 but have not included the voltage board(the one with the Jumpers on.
BARCO BG 808
1. DIAGNOSTIC BOARD R762506
2. POWER SUPPLY R7621705
BOARD 3 R7621745
BOARD 4 R7617481
BOARD 5 R762105.5
BOARD 6 R7622685 (ALSO NUMBER ACROSS 2 CHIPS =R7622268 S)
BOARD 7 R7622675
BOARD 8 R762503
CINE 8
1. DIAGNOSTIC BOARD R769073
2. POWER SUPPLY R7621706
BOARD 3 R762720
BOARD 4 (CANNOT FIND A NUMBER)
BOARD 5 R7621055
BOARD 6 R762808
BOARD 7 R7622675
BOARD 8 R7625035
dentree
Posted: Thu Dec 25, 2014 9:29 am    Post subject:
i do not know which is the control board or what the control board and RWI chip is
Posted: Thu Dec 25, 2014 9:35 am    Post subject:
The control board is attached to the cover that you lift to see all the boards you have listed. There is a metal cover over the control board that you will need to remove to see the control board. Its the same for both projectors. Also just to be clear you have a BG808 not a BG808s. The s has Sony tubes.
Posted: Thu Dec 25, 2014 10:25 am    Post subject:
Im quite sure the set can be made to work, but id love to know if it worked prior to him buying it. We may never know.
Doesnt the 808 have 180DVB tubes? They cant be used in the place of P16s, youll never get it to focus. I want to know the exact numbers on those tubes in that Cine 8 though!!
I dont celebrate it Keith, but it was bloody good to have a day off anyway!! How about you?
dentree
Posted: Thu Dec 25, 2014 11:16 am    Post subject:
The RWI CHIP NUMBERS:
BARCO CINE 8 =RC 5 VER 6.01
808 GRAPHICS = RWI VER 5.06
BARCO CINE 8 TUBE INFORMATION
RED =BARCO P16LNP07RJA
GREEN = NO INFORMATION STICKER PRESENT
BLUE = PANASONIC P16LNP07BMB
dentree
Posted: Thu Dec 25, 2014 11:24 am    Post subject:
The information on the BRCOGRAPHICS 808 shows that they are all BARCO tubes and as you said they are in fact all 180 designated tubes
dentree
Posted: Thu Dec 25, 2014 11:42 am    Post subject:
This is the original advert on ebay from the seller:
It won't tell you a great deal, except to say that the fact that he bought it from Curt suggested to me that it would be an OK set to buy
Trevor
Unit was purchased from Curt Palme four years ago. Unit is silver over blue combination. The unit has 20,000 hours on it. Curt went over this unit with a fine comb and replaced alot of Barco's gremlins for the unit. He also fitted three brand new NEC tubes. I bought some HD145 colour corrected lenses. I bought an adaptor bracket kit for it but got sent to a wrong address and was too expensive to make another purchase. The unit has only been fired up twice to test and do a quick focus. It has been sitting in my spare room for over four years and just has to go! The unit has some wear on it. The keypad door is broken. The top case has a crack at the rear. I was going to have the case professionally repaired and spray painted black. Money never presented itself to do this, so it is how I received it. Shipping from America, the door vibrated loose and disconnected and broke. And its believed this is how the crack at the rear of the case happened. The Cine8 badge isnt attached to the lid. Also, there were screws missing from the case when I received it. I had every intention of refurbishing the set, so this wasnt fixed immediately.
*** Edit; I re-read the ad and its probably not entirely obvious, but thought i'd mention it. The tubes are still brand new. There is less than thirty minutes on them. I simply turned it on to see it worked, watched a blu-ray and calibrated it as it played. I literally bought and shelved this unit. I was planning on buying my own place and hanging it, but that never eventuated. The lenses that came with the unit originally were HD8's I believe? They have no filtering on them. They arent the best lenses I have seen, but I always had the intention of fitting the HD145's. I had the HD8's on when i fired the unit up to test it was working and it looked great. Anyway...
Given the nature of this beast, shipping is not something I want to entertain unless its a fair offer. I am willing to help lifting this thing into a car/ute/van at both ends... always keen to help where I can.
I would love to see it fired up complete. Such a shame to get rid of this. I simply need the money and it has to go. I have been putting it off for some time now. There is just no room for it in my new home.
Hulio
Posted: Thu Dec 25, 2014 12:06 pm    Post subject:
Someone messed up that projector big time. Those tube are LC tubes and cine 8 (808) is a AC machine.
Even not all boards are genuine Cine 8.
dentree
Posted: Thu Dec 25, 2014 12:37 pm    Post subject:
bugger, this saga seems to be going from bad to worse, if you have not already done so, above is the ebay information from the seller that prompted me to buy it.
Thanks for the input Hulio.
redfox001
Posted: Thu Dec 25, 2014 12:45 pm    Post subject:
XG has a terrible bandwidth.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=37160.html
There is no proof of the contrary yet.
(If you exchange tubes for the focus issue try exchanging focus yokes.)
dentree
Posted: Thu Dec 25, 2014 12:53 pm    Post subject:
To Case and Keith,
If you have read Hulio's post and he is correct then it would explain the focus problem,
your thoughts would be appreciated to see if you both concur with Hulio's assessment of the situation, and if he is correct, what if any would be the next move.......that is of course if there is any next move, and indeed if Hulio is right, then there would be no point in putting these "new tubes" into the BG 808 would there?.
We would in fact have 2 separate issues here 1. A major optical problem and 2. the electronic shut down of the Cine 8
redfox001
Posted: Thu Dec 25, 2014 12:54 pm    Post subject:
But he can focus the tubes at 100. So no optical problem I think.
dentree
Posted: Thu Dec 25, 2014 12:57 pm    Post subject:
The focus is almost (but definitely not tight enough) at ZERO not 100
redfox001
Posted: Thu Dec 25, 2014 12:59 pm    Post subject:
But you don't have an optical issue. That is the point.
dentree
Posted: Thu Dec 25, 2014 1:13 pm    Post subject:
Point taken redfox, and as my knowledge of this subject is so limited I really do appreciate everybodys input and thoughts, because without such great interest and support I would have shot myself by now just from pure frustration, but it you guys that keep me optimistic about a reasonable solution and outcome from what I termed in my first post as a 'disaster"
Page 7 of 27
