Add Glycol To G70 Without Removing Tube?
piratepowwow
Posted: Thu Nov 06, 2014 3:20 pm    Post subject: Add Glycol To G70 Without Removing Tube?
The G70 is mounted on the ceiling.
The red tube has a bubble in it that's reflecting a mirror image under the screen I would like to get rid of.
Can I add glycol without removing the tube?
Thanks!
Posted: Thu Nov 06, 2014 4:59 pm    Post subject:
Yes, but then you'd have to unmount the whole projector from the ceiling... Smile
Maybe adding masking tapes just like the ones used on the XG LCs would help to solve the problem without pain.
Posted: Thu Nov 06, 2014 5:04 pm    Post subject:
That green has a little wear on it, gjaky. Wink
Yeah, no way to do it without A) removing the tube from the projector, or B) removing the projector for the ceiling.
Posted: Thu Nov 06, 2014 5:09 pm    Post subject:
It's not my merit. Very Happy The picture was posted originally by SpankyHam, I should have noted...
Posted: Thu Nov 06, 2014 7:28 pm    Post subject:
No, you can't. Take the tube out.
piratepowwow
Posted: Thu Nov 06, 2014 9:01 pm    Post subject:
If I could do it without taking the tube out by unmounting it from the ceiling...
Why can't I do it with it still mounted to the ceiling? One syringe takes air out, the other puts glycol in?
Posted: Thu Nov 06, 2014 9:02 pm    Post subject:
Do it at your own risk. The tube needs to partially come out to access the glycol chamber, and I personally wouldn't risk snapping the neck while the tube is partially out of the set.
Posted: Thu Nov 06, 2014 9:18 pm    Post subject:
Not to mention, you can remove a tube from a G70 in less than 10 minutes.
piratepowwow
Posted: Thu Nov 06, 2014 9:45 pm    Post subject:
If the tube has to partially come out that defeats the purpose I was going for - not having to re-converge.
Thanks again.
Posted: Fri Nov 07, 2014 12:04 am    Post subject:
You shouldn't have to reconverge even if you pull the tube. You will have to touch it up, but that's it.
Posted: Fri Nov 07, 2014 4:22 am    Post subject:
Now there is a pic I haven't seen for a long time. Laughing I bought that off of ebay from a seller who misrepresented the pj. Back then ebay didn't give me the time of day. Now I could probably get a refund, keep the pj and ebay would throw in a Lamborghini for my troubles. Shocked Mr. Green
