papalek
| Posted: Sun Oct 19, 2014 8:27 pm Post subject: 801s scan fail |
I was watching it and the pic started to flicker. Now it is black with an occasional flicker and the scan fail led is lit. I changed both the vertical and horizontal boards and no change.
_________________ My current list of PJ's AmPro 1 1/2-4600,4200, 1/2-3600,2600.
I do love my AmPro's
| Posted: Sun Oct 19, 2014 9:37 pm Post subject: |
Check the 17 volt line to see if it's still at 17 volts. Are all the yellow LEDs lit?
papalek
| Posted: Sun Oct 19, 2014 10:32 pm Post subject: |
I will check the 17 volt and yes all the yellow LEDs are lit.
AVphile
Joined: 02 Dec 2008 Posts: 334 Location: Ottawa, Ontario
| Posted: Tue Oct 21, 2014 2:08 pm Post subject: |
I have parts if you need them.
_________________ AVStefan
Old setup: HDFury3 -> BG-808s -> HD-145
New setup: JVC D-ILA -> Stewart StudioTek 130 G4
| Posted: Tue Oct 21, 2014 2:27 pm Post subject: |
Scan fail can also be caused by the power supply, either video switching board, the H shift board next to the H board, bad yoke connectors, yoke switches.
papalek
| Posted: Sun Nov 09, 2014 3:45 am Post subject: |
I finally got a chance to check this thing out. The voltage was 17.6 volts. I set it at 17 volts. Not sure if that was off enough to cause the problem or it was something else. It has been about 3 weeks since it was on. The scan led is off but all the adjustments were all out of wack as well. I spent some time adjusting things. Even had to adjust the master H width trim pot. But it is now working perfect and looks great.
