HDMI Source to CRT TV with only DVI Input
erikjohn
Posted: Tue Oct 14, 2014 7:25 pm    Post subject: HDMI Source to CRT TV with only DVI Input
What is the best and cheapest solution for this?
EJ
Posted: Tue Oct 14, 2014 8:07 pm    Post subject:
http://www.ebay.com/sch/i.html?_nkw=monoprice%20hdmi%20to%20dvi%20cable&clk_rvr_id=713621139511&mfe=search
Posted: Tue Oct 14, 2014 9:42 pm    Post subject:
The cables Tom linked to will probably work fine, provided that A) the DVI input on the TV can handle DVI-D, and B) that the input on the TV is equipped with HDCP. The first is probably true; the second definitely isn't a given. If you can find reference to HDCP in the manual for the TV, you're probably in good shape.
Cheers,
erikjohn
Posted: Wed Oct 15, 2014 11:30 am    Post subject:
The TV is a Sony KP-46WT500 and per the service manual the input is listed as DVI-HDTV and is compliant with EIA-861 standard and is not intended for use with personal computers.
EJ
Posted: Wed Oct 15, 2014 4:17 pm    Post subject:
No but you could set the PC to 1080i output OR if it's a lap top with limited video, use a scaler like a VP50.
PC----VP50-----TV
Posted: Wed Oct 15, 2014 4:19 pm    Post subject:
Cheers,
Being 2003 probably not HDCP. That came in in 2005. He could use one of the spliters that we so like here. You can provide the link for that right?
erikjohn
Posted: Fri Oct 17, 2014 12:24 pm    Post subject:
I am not gong to be connecting a computer just game systems and dvd/blu ray players. I have been using a 2-3 year old Monoprice HDMI switcher that has analog audio out to the dvi input and analog audio in's but with some input sources it seems to have handshake issues. I guess for me the key is I need to switch multiple hdmi so I cannot rely on the single analog audio out of the source as that will not work for switching. I don't want to spend the amount on a switcher that costs 50%-75% of what I can replace the Sony CRT with a LCD for.
EJ
erikjohn
Posted: Fri Oct 17, 2014 12:52 pm    Post subject:
Possible solution may be the HDF1 Nano GX with a breakout cable to my component video input if there is not a better solution. At the end of the day I can get cheap hdmi switchers that I think will work bette but the hurdle it is getting the audio extracted analog.
EJ
