petee2
Joined: 12 Mar 2012 Posts: 11 Location: New jersey USA
| Posted: Mon Oct 06, 2014 1:17 am Post subject: SONY 1030Q1 |
Question
I just picked this up 1030Q1 FREE . (I know its old but the bulbs are clear and show NO wear)
I was wondering can it be used for a REAR projection I did not see this in the manuals
I was going to use it for a halloween projector then re give it away
( it will be in protected shed outside focusing behind plastic )
I did not want to place the projector in front and am hoping this can be done..
I have other crts I love them !!!!!
Any help??
| Posted: Mon Oct 06, 2014 1:28 am Post subject: |
First off, they are not BULBS, they are TUBES!
Yes, the H yoke connections need to be reversed as well as some of the convergence board connectors. It's been too long for me to remember, but you should find the info here:
http://www.curtpalme.com/Sony10xx_Downloads.shtm
If the 1030 owner's manual doesn't cover it, download the 1031 install manual.
Have fun with it!
petee2
| Posted: Mon Oct 06, 2014 1:54 am Post subject: |
+Sorry bout saying bulbs thank you for the info
| Posted: Mon Oct 06, 2014 2:04 am Post subject: |
Hey, it's my main job around here, giving people goodnatured crap.
| Posted: Mon Oct 06, 2014 2:11 am Post subject: Re: SONY 1030Q1 |
| petee2 wrote: | Question
Any help?? |
Yes, it works great! See my Sony 1040's doing the eyes in this video:
http://www.youtube.com/watch?v=NN7H_2ziBQU
and here:
http://www.youtube.com/watch?v=F3q-wd6CWYs
| Posted: Mon Oct 06, 2014 2:45 am Post subject: |
The plugs are on the left side of the convergence board as you look from the rear. There is 6 plugs on the board and three leads to connect.
The deflection yokes connect to the board to the left of the convergence board.
There is a heap of switches on the convergence board with some sets that need to be set so the convergence will work.
| Posted: Mon Oct 06, 2014 3:08 am Post subject: |
Do it with the power off!
| Posted: Mon Oct 06, 2014 3:50 am Post subject: |
| AnalogRocks wrote: | | Do it with the power off! |
As much as youd think that part is obvious
| Posted: Mon Oct 06, 2014 3:56 am Post subject: |
| CasetheCorvetteman wrote: | | AnalogRocks wrote: | | Do it with the power off! |
As much as youd think that part is obvious  |
One of my 1040's has a deflection burn likely caused by pulling the plug on the green to switch the scan with the power ON
| Posted: Mon Oct 06, 2014 4:39 am Post subject: |
There is a board that causes that if it fails too, my 1001 did something like that on all three tubes, but didn't burn them!! They were black already, so you never know.
| Posted: Mon Oct 06, 2014 4:51 am Post subject: |
| CasetheCorvetteman wrote: | | There is a board that causes that if it fails too, my 1001 did something like that on all three tubes, but didn't burn them!! They were black already, so you never know. |
Hmmm maybe but it was only on the green tube.
| Posted: Mon Oct 06, 2014 7:00 am Post subject: |
In that case youre most likely correct!
