Doubts dual boot XP/8.1
[Frankie]
Posted: Mon Sep 29, 2014 10:43 am    Post subject: Doubts dual boot XP/8.1
Hi! I have got some doubts with a graphic card that i have bought, a Nvidia GeForce 6600GT. After i have receveid it, i have just noticed a bad capacitor on it, i've replaced it and i tried the video card. The card works on my PC that has got Windows 8.1 but i can't install the drivers because of a problem with compatibility with the OS (and i'm ok with that) but If i use Windows XP emulated on VirtualBox, the computer doesn't see the graphic card. Looking on Device Manager, sees the card as "Video Controller (VGA Compatible)and, surfing the internet, then i found that it's normal that the graphic card isnt' recognized correctly due to some software components that i can't install, so, always surfing the internet, i found that there's this system called dual boot, i informed myself a bit on how it works etc. but i still have some doubts:
- Can i install windows XP 32-bit on a PC that has installed Windows 8.1 64-bit?
- There can be some problems with compatibilty between hardware and software, because i bought my PC few months ago and Windows XP is quite old, i mean there can be issues with that?
- I have got two HD on my PC, one 1TB and the other one 150GB. Can i install Windows XP on the 150 GB HD without partioning the 1TB HD?
Thank you and have a good day!
the big E
Posted: Mon Sep 29, 2014 6:53 pm    Post subject:
I have done this before
Disconnect the windows 8 drive and install xp on the other drive
The generic drivers are normal on any windows install without the hardware drivers
I will warn you xp has no support from Microsoft now
If you need any help let me know the make and model of the machine
crt king of black
the big E
Posted: Mon Sep 29, 2014 6:54 pm    Post subject:
crt king of black
[Frankie]
Posted: Tue Sep 30, 2014 9:02 am    Post subject:
Hi! Thank you for your help, i have successfully installed XP 32 bit and also the graphics card, but now i have got another problem: i can-t return back to Windows 8.1. I-ve seen on the internet that when you install another OS on the PC, a screen came out telling you what OS you want to start, but to me it doesn-t appear nothing, the PC starts Windows XP without asking me to choose between the two. Then, to install XP, i-ve followed a video that tells to go in BIOS\Advanced mode\sata configuration and to choose IDE instead of AHCI (This is the video: http://www.youtube.com/watch?v=as0-g0bl85A) but even if i choose AHCI instead of IDE, i can-t turn back to Windows 8.1, when it-s about to start the OS the PC reboot.
Another problem that i-ve found is that the graphic card can-t do interlaced resolution even if there-s the option to. If i choose for example 1920x1080i72Hz it says "Error custom resolution test failed".
Posted: Tue Sep 30, 2014 1:21 pm    Post subject:
Is windows 8 on the same hard drive as XP?
[Frankie]
Posted: Wed Oct 01, 2014 11:50 am    Post subject:
No, i have two HDD's, Windows 8.1 is installed on the 1TB one and XP on the 150GB one.
Posted: Wed Oct 01, 2014 1:23 pm    Post subject:
Then I'll assume you did as E said and removed the Win 8 drive and then installed XP on the remaining drive. This is why you do not show the dual boot screen. When XP was installed the Win 8 OS was not there to be seen, even on a different drive so it was not able to create info for it in the boot.ini file.
You have a few options. One is, if on startup you have the option to select boot device you can just select back and forth which drive you want to boot up. Just select the drive to boot according which OS you want.
Or you can try an XP repair from boot while the Win 8 drive is installed. Never tried this method so I am not sure.
Or do a complete XP install, again with the Win 8 drive installed.
Or you can try to edit the boot.ini file but this can be difficult if you do not do it exactly right. There is a process under recovery to discover other OS's but it does not always recognize newer Windows OS's.
Or you can edit the Win 8 boot but you need special software for that but I believe it is free.
Which ever you decide to do, the drive with the correct boot.ini file must be set to boot first, other wise the dual boot screen will not come up.
the big E
Posted: Mon Oct 06, 2014 8:27 pm    Post subject:
Some motherboards allow you to select the boot drive in the bios screen(mine does)
I forgot to mention that if you want to use the windows boot menu you will need to install xp first then windows 8 even though your using seprate drives
crt king of black
