the big E
| Posted: Thu Sep 25, 2014 12:46 am Post subject: Gunk in blue tube |
Guys I have noticed from where I didn't run my marquee for a month
My blue tube developed gunk in the cooling chamber which has now on the entire c element
How should I go about getting it clean(the other tubes are ok and clear)
I know I would have to pull the tube to do it
| Posted: Thu Sep 25, 2014 2:15 am Post subject: |
Pull the C element, order stainless screws from me and fill washers, that's where the gunk came from, and you need new glycol. Change the bellows to be on the safe side as well.
the big E
| Posted: Thu Sep 25, 2014 3:33 am Post subject: |
Who can I get a replacement bellows from?
I have plenty of glycol so that's no problem
what will the screws and washers run price wise?
If they are cheap I may do all three tubes to prevent the others from doing this
It started back in December during the time you was repairing the clm(it was small and just gunk then) and just got worse
dvh99
| Posted: Thu Sep 25, 2014 10:21 am Post subject: |
ive had the same problem and also on the blue (coincidence).
leave the other tubes alone but get the nashou bellow if you didn`t already.
you know it`s a mix of glycol and glycerol? 75-25.
the nashou bellow doesn`t need to be glued.
the big E
| Posted: Thu Sep 25, 2014 1:14 pm Post subject: |
| dvh99 wrote: | ive had the same problem and also on the blue (coincidence).
the nashou bellow doesn`t need to be glued. |
Thanks man I will contact Nash about the bellow
He has helped me out when I upgraded my marquees belly fans(a lot quieter)
| Posted: Thu Sep 25, 2014 1:28 pm Post subject: |
Should be $10 with shipping, email me!
| Posted: Thu Sep 25, 2014 4:37 pm Post subject: |
Also, I think it's important to rinse the chamber with 90% Isopropyl alcohol to kill all the fungus spores before adding the Glycol,
the big E
| Posted: Fri Sep 26, 2014 1:46 am Post subject: |
| draganm wrote: | | Also, I think it's important to rinse the chamber with 90% Isopropyl alcohol to kill all the fungus spores before adding the Glycol, |
would clr work also?
just wondering(I do have the isopropyl alcohol if it don't)
the big E
| Posted: Fri Sep 26, 2014 1:47 am Post subject: |
curt I sent you a email about the screws and the win parts I need
| Posted: Fri Sep 26, 2014 1:51 am Post subject: |
Been in a training session all week, give me a day to respond!!!
the big E
| Posted: Fri Sep 26, 2014 3:00 am Post subject: |
| Curt Palme wrote: | Been in a training session all week, give me a day to respond!!!  |
ok mate i am in no rush as i have been building my htpc and finely got it running smooth
now if can get blu ray playback on it i will be set as it would allow me to ditch three different compnents
