modelaratrod
| Posted: Sun Sep 07, 2014 4:10 pm Post subject: Just received my EXT-FULLHD v3 and I can't get it to display |
Just received my EXT-FULLHD v3 and I can't get it to display video. To a Marquee 8500LC
I've tried the dip switch settings and both HDMI ports and it's a no go. I have both the HDFury 2 & 3 and they work fine with the same cables. When the Moome is connected to the HDMI out of my reciever the reciever starts to cycle the HDMI output off and on, and it happens on both HDMI inputs on the Moome.
Any thoughts or suggestion s?
stridsvognen Guest
| Posted: Sun Sep 07, 2014 4:49 pm Post subject: |
Try connect it directly to your source/ player.
modelaratrod
| Posted: Sun Sep 07, 2014 8:59 pm Post subject: |
Same result, I hooked it up to my Directv and blue-ray no go.
I hooked it up to a laptop with HDMI and set the laptop to all the resolutions and refresh rates listed in the pdf for the v3 and it does the same thing.
modelaratrod
| Posted: Sun Sep 07, 2014 9:47 pm Post subject: |
The power supply for the Moome? It tests 5.9 vdc & 13.6 ma
modelaratrod
| Posted: Sun Sep 07, 2014 9:53 pm Post subject: |
modelaratrod
| Posted: Sun Sep 07, 2014 10:22 pm Post subject: |
VSync Out Of Range
And the source keeps turning on and off?
modelaratrod
| Posted: Sun Sep 07, 2014 11:24 pm Post subject: |
I've tried all of these on two pc's
PC mode 640X480 60HZ 72HZ 75HZ 85HZ
800X600 56HZ 60HZ 72HZ 75HZ 85HZ
1024X768 43HZ 60HZ 70HZ 75HZ 85HZ
1152X864 60HZ 70HZ 75HZ 85HZ
1280X1024 43HZ 60HZ 75HZ 85HZ
1600X1200 48HZ 60HZ
1440X960 43HZ 60HZ 72HZ
modelaratrod
| Posted: Sun Sep 07, 2014 11:26 pm Post subject: |
I believe the sync is correct as both the HDFury 2 & 3 both work fine. I did try to change the split shun jumpers to negative sync just to try it and it still does the same thing. Yes I just swapped H & V no change.
| Posted: Mon Sep 08, 2014 1:45 am Post subject: |
I have one doing that too. No picture except a blue tinted one at 480p only. HDMI from Bluray get's pissed off too.
modelaratrod
| Posted: Mon Sep 08, 2014 2:38 am Post subject: |
| AnalogRocks wrote: | | I have one doing that too. No picture except a blue tinted one at 480p only. HDMI from Bluray get's pissed off too. |
Analog did yours once work and then sh*t the bed?
This one is brand new ordered from Moome a month ago and has never worked.
| Posted: Mon Sep 08, 2014 2:44 am Post subject: |
| modelaratrod wrote: | | AnalogRocks wrote: | | I have one doing that too. No picture except a blue tinted one at 480p only. HDMI from Bluray get's pissed off too. |
This one is brand new ordered from Moome a month ago and has never worked. |
It did work until the fire/flood.
I got this one used, it needs an overhaul.
Yours sounds like its just a bad unit out of the box.
modelaratrod
| Posted: Mon Sep 08, 2014 2:55 am Post subject: |
I figured with the low production the quality control would be there and I was overlooking something.
gregstv
| Posted: Tue Sep 09, 2014 7:12 am Post subject: |
I am sending mine back to be checked this week. Try 1080i@60. This is the only resolution I can get to work.
modelaratrod
| Posted: Fri Sep 19, 2014 12:33 am Post subject: |
SO after trouble shooting with every combination of rez & refresh it's DOA and I sent it back to Taiwan this morning.
| Posted: Wed Oct 01, 2014 1:23 am Post subject: |
Did you open it up and set the jumpers correctly??
| Posted: Wed Oct 01, 2014 8:03 am Post subject: |
| modelaratrod wrote: | SO after trouble shooting with every combination of rez & refresh it's DOA and I sent it back to Taiwan this morning.  |
Hey shoot me his address will you please? I still need to send mine in for an overhaul.
TIA
